LEAK!! Waterpump - Where Could It Be Coming From?
Old Apr 26, 2006 | 05:32 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default LEAK!! Waterpump - Where Could It Be Coming From?
SO I go to fill up my car with fluids again today get to the rad. All full. Got under the car and noticed a few drips on my shirt
Theres a leak somewhere coming from the waterpump area, small as ****, maybe 1 drip every 15 seconds
Its coming form the bottom right corner of the pump, not where it meets the block on that seem but it is in a bit, like its coming from the inside of the pump, where the hell can it leak from there?
I tried checking everything but its so hard to see right there, got my top timing cover off, alt moved back and I just cant see where its coming from, i can see where it drips but I just cant stop the dripping
How do I find this leak and where could it be coming from?
Old Apr 26, 2006 | 06:13 PM
Runnerdown's Avatar
Default Re: LEAK!! Waterpump - Where Could It Be Coming From? (PINKS)
there is always one or two weep holes on the water pump. if that is leaking the seals internally have failed and it needs to be replaced.
Old Apr 27, 2006 | 02:33 AM
PINKS's Avatar
Default Re: LEAK!! Waterpump - Where Could It Be Coming From? (Runnerdown)
no weep holes are leaking, I know where those are, I cant see what its leaking from expletive
Old Apr 27, 2006 | 06:17 AM
HBoy's Avatar
Either the bearing is gone in the water pump and it needs to be replaced or it's the o-ring on the water outlet tube on the back of the engine.
Old Apr 27, 2006 | 01:39 PM
PINKS's Avatar
ok, so im missing the bottom right water pump bolt, expletive, i wonder where that went, but the leak seems to be ocming fomr above it....
Would this fix it or is there something else?
WingedMan
Apr 26, 2021 05:03 PM
JDMsalinger
Aug 18, 2013 10:05 AM
adio8352
May 3, 2011 07:45 AM
PINKS
13
Apr 27, 2006 01:38 PM
RenoRacing
Oct 27, 2002 08:40 PM
