shaking car at 35mph
ok i had drop my firlfriends car with a 2 inch drop using some sprint springs but after the car was droped everytime i drove from 25-35 mph the car vibrates what would it be
?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by looxs »</TD></TR><TR><TD CLASS="quote">are your tires properly balanced? axels?</TD></TR></TABLE>
yeah make sure both tires are balanced and axels are properly installed.
what kind of vibration? is it coming from the engine or is it suspension related?
check all your main suspension components. it could really be anything steering/suspension related.
-ball joints
-upper control arms
-tie rods (inner and outer)
-lower control arm bushings
-wheel bearings (definately will cause vibration)
-radius rods
did you get an alignment after you lowered it?
-ball joints
-upper control arms
-radius rods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5litereater »</TD></TR><TR><TD CLASS="quote">?
-ball joints
-upper control arms
-radius rods
did you get an alignment after you lowered it?</TD></TR></TABLE>
Summed it up man!
-ball joints
-upper control arms
-radius rods
Summed it up man!
the toe is now messed up get it aligned
you definately need to get it aligned due to the drop.
however, my first guess is that you didnt tighten the lugnuts completely....
otherwise, just whatever everyone else said. just look for what has play or get your tires balanced again.
95civic LS
Mar 30, 2005 03:24 PM
