Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Crv problem
Old Apr 26, 2006 | 12:40 PM
freeway's Avatar
Default Crv problem
1998 drivers side power window will not come up. All others will roll down and up. It is not locked. Any suggestions?
Old Apr 26, 2006 | 05:41 PM
Ross 2.0's Avatar
In a Junkyard near you.
hold the switch while opening and closing the door a few times. If that doesn't make it work momentarally then your motor may have gone bad.
Old Apr 28, 2006 | 04:26 PM
crypticcivic's Avatar
Default Re: (MooGoCow3)
if you know someone else with a crv. switch over the switches and see what happens. if that dont work then its the window regulator motor. replace the motor and the window run channel.
Pauly321
Dec 2, 2016 12:15 PM
gliaZeD
Aug 19, 2011 11:15 AM
da_ska
May 31, 2009 02:32 AM
hometheaterman
Nov 15, 2005 10:03 PM
