i got a question about my ross pistons
Old Apr 26, 2006 | 06:34 AM
h22_crx's Avatar
Default i got a question about my ross pistons
i have a h22 with ross pistons the problem is i am going to run a turbo and you need.006 for the pistons to wall i only have .003 for the piston to wall
the ppl from the mach shop thinks that .006 is alot.
help
Old Apr 26, 2006 | 06:47 AM
mononctsi's Avatar
Oh, I can tell you to follow Ross clearance or you might be sorry. They expand *a lot* and need all that clearance.
If you don't follow their directives, they will scuff. They could even seize in extreme conditions.
Been there, done that.
We run them at 9 thousands on our Mirage. Funny thing is that you can hardly hear any slap from them...
Old Apr 26, 2006 | 07:19 AM
earl's Avatar
Default Re: i got a question about my ross pistons (h22_crx)
.006" clearance is huge when most turbo pistons use about .0035". I would think they would knock like crazy. Is your block sleeved?
Old Apr 26, 2006 | 09:44 AM
h22_crx's Avatar
Default Re: i got a question about my ross pistons (earl)
yeah its has darton sleeves
Old Apr 26, 2006 | 11:24 AM
TOM J's Avatar
Old Schooler
This is Tom J from Arias Pistons.
Run The .006 it calls for or you will Have a huge problem.
There are some people on this bord that clame to know about pistons dont listen to them. Your pistons will be fine @ .006 if a piston calls for 003 and it is @ .006 then you will have a little nock in your motor but it will still run fine. It will just make noise.
Pistons that call for .006 wont make noise if they use the right piston cam on the piston.
If still in doubt call Ross they will tell you what you need to know
Old Apr 28, 2006 | 06:08 AM
h22_crx's Avatar
Default Re: i got a question about my ross pistons (TOM J)
will i have to get different pistons rings
Old Apr 28, 2006 | 06:11 AM
h22_crx's Avatar
there the stock cams
Old Apr 28, 2006 | 06:37 AM
mononctsi's Avatar
BTW, we run .009 because Ross tells to add .002 for the nitrous. Then we added an extra .001 for luck.
I'm not saying to run .009 on yours, just to follow Ross specs for your application.
Old Apr 28, 2006 | 09:54 AM
h22_crx's Avatar
Default Re: (mononctsi)
i am not going to run nos
Old Apr 28, 2006 | 08:28 PM
mononctsi's Avatar
They say to use more clearance if you use nitrous, but .006 is the spec for turbo NO nitrous (on mines anyway).
But anywho, I think the Arias piston guy sums it up pretty nicely.
Old Apr 29, 2006 | 03:54 AM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx &raquo;</TD></TR><TR><TD CLASS="quote">there the stock cams</TD></TR></TABLE>
The "cam" Tom is talking about is the shape of the piston.You may want to start with new rings if you already gapped them for the smaler bore.
Glenn
Wheelman-CZ
Jan 7, 2008 12:52 AM
1fastEK9
Oct 29, 2007 08:25 AM
h22_crx
May 4, 2006 04:57 AM
h22_crx
Apr 28, 2006 06:08 AM
