opinion all motor or boost
Old Apr 25, 2006 | 08:03 PM
ilikehonda's Avatar
Default opinion all motor or boost
trying to decide what i want to do. my goal is for a low 13 sec 1/4 mile. i dont really care what it puts down to the ground. here is my current set up:
jdm h22
Honda s200
ground control coil overs with skunk 2 800lb race springs in the back
tokico illumina 5 way adjustible struts all the way around
limited slip
2 1/4 exhaust
cia
my current time is a 14.8 on 2 hurt axles should be a 14.5 when i can finally launch.
so I have 3000 to spend. i want the most dependable set up what will get me down the track with the best time.
this will be on a stock bottom end either way. sooo hit me up yall
im persionally leaning all motor
thanks guys
Old Apr 26, 2006 | 02:02 AM
rsintegra's Avatar
Default Re: opinion all motor or boost (ilikehonda)
Here are some good sites for you to check out, if you hadn't done so already:
https://honda-tech.com/zerothread?id=691830
https://honda-tech.com/zerothread?id=730548
https://honda-tech.com/zerothread?id=1232150
As much as I respect all motor, given a proper setup and tune for 3k, low 13's are much more possible with forced induction than the all motor direction. Granted, both all motor and boost setups can achieve your goal...it's a matter of preference, knowledge, and tuning.
Keep in mind, should you go the turbo route, you can always upgrade you turbo and produce more hp. If you upgrade your block and such, you can choose to upgrade from a small turbo that can easily reach your low 13 goal, and surpass it easily by simply replacing the turbo with a larger one. All motor applications cannot reach the torque and hp figures produced by properly built turbo setups. Oh, and driving a mildly to highly modified boosted car requires more skill than N/A...why? traction issues...N/A cars typically have a linear powerband, whereas its boosted counterpart has an exponential powerband. Imagine something of this effect: 140whp at 4000rpm, and then 350whp at 5000rpm. That's turbo for ya. I can go on and on...
itsukivr6
Nov 19, 2011 03:09 PM
Teddieb15
Dec 4, 2008 09:40 AM
dragsol
Sep 10, 2008 09:19 AM
ninjastance_batmang
Jul 26, 2006 06:43 AM
GEN2TEG
Dec 8, 2002 08:07 AM
