EP3 K20A3 Vtec Actuation
Old Apr 25, 2006 | 07:34 PM
Si_chRis's Avatar
Default EP3 K20A3 Vtec Actuation
I was reading about the K20A3 in the new Honda Tuning and I found out that the K20A3 has no Vtec actuation on the exhaust camshaft. I thought it has it on both cams but wow, the K20A3 is like Vtec-E. It runs on 12 valves under 2200 rpm, then 16 valves above 2200rpm, then it has the Vtec engagement but theres none on the exhaust camshaft profile. This just amazed me because I was planning on buying a EP3, now it has changed my mind about it.
Old Apr 25, 2006 | 11:48 PM
KOREAN's Avatar
Default Re: EP3 K20A3 Vtec Actuation (JDMaLLDAy050)
That is correct.
You'll also hear that the K20A3 motor is a horrible motor to work on unless you pursue forced induction.
I believe ^^
Old Apr 26, 2006 | 04:27 AM
BarracksSi's Avatar
It still responds decently to bolt-ons -- between 20 and 30 whp on mine, depending on whose stock dyno you believe. And if you're cheap on gas, the ability to run 87 octane is nice.
Old Apr 26, 2006 | 07:34 AM
Mechanic's Avatar
I'm curious: What exactly were you planning that you cannot now do?
Old Apr 26, 2006 | 09:13 AM
Si_chRis's Avatar
Default Re: EP3 K20A3 Vtec Actuation (Mechanic)
I just thought that all Vtec dual cam honda engines have Vtec engagement on both cams. I want an EP3 because it's a hatch but I also want it to be quick. Most of my friends say that the EP3 is slow, even an Integra LS is faster. But If i did mods to the intake, Header, test pipe to a cat back, would it be alot faster than it already is or just a little bit? Also, does Vtec kick in hard or does it feel like a SOHC Vtec?
Old Apr 26, 2006 | 09:43 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mechanic &raquo;</TD></TR><TR><TD CLASS="quote">I'm curious: What exactly were you planning that you cannot now do? </TD></TR></TABLE>
well read his sig lol
Old Apr 26, 2006 | 10:21 AM
tsr_75th's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMaLLDAy050 &raquo;</TD></TR><TR><TD CLASS="quote">Most of my friends say that the EP3 is slow, even an Integra LS is faster.</TD></TR></TABLE>
LMAO!!! I don't think so..first of all it all depends on the driver. Stop listening to your friends. Go drive the car before you make an opinion. Personally I own one and I can vouche that it IS NOT slower than a LS Integra. I've beaten modded GSR with my "slow" EP3. BTW Im stock with only an air filter.
Old Apr 26, 2006 | 04:24 PM
BoBoChan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMaLLDAy050 &raquo;</TD></TR><TR><TD CLASS="quote">Also, does Vtec kick in hard or does it feel like a SOHC Vtec?</TD></TR></TABLE>
pretty sure it doesnt 'kick in' like your thinkin..
Old Apr 26, 2006 | 05:27 PM
HAMB0NE's Avatar
Default Re: EP3 K20A3 Vtec Actuation (BoBoChan)
Theres no real 'kick' like most other b-series motors, but the motor pulls much harder in the lower end. Stock for stock an ep is about the same as a gsr and responds pretty well to bolt ons. Your not going to get a 13 second ep without boost or swap though.
Old Apr 26, 2006 | 05:44 PM
Andrey's Avatar
record for NA K20A3 EP3 with stock cams is 14.2 on 1/4 mile
noone can beat that record for more than year now..
although guy ran setup with i/rh/e and slicks i believe no k-pro
if u beat that record u can get 100 bux i believe lol
for more info go search on i-vtec.net for guy aRz
Old Apr 26, 2006 | 06:51 PM
Si_chRis's Avatar
Default Re: (Andrey)
Thanks for the info, ever since i sold my ek hatch, i ve been looking for a new car but i want somthing newer so i was thinking about getting a EP3. Well Since what u guys said, i'll look into it more and see if it's worth the money
Modified by JDMaLLDAy050 at 8:06 PM 4/26/2006
Old Apr 27, 2006 | 08:10 AM
Jeenyusss's Avatar
Default Re: (JDMaLLDAy050)
i have a 2002 si,, no was a ls integ is going to beat you unless you suck at driving and he is modded up the ***. the ep3 is no rsx-s or evo, but witha couple mods ulll be happy imo
Old Apr 29, 2006 | 10:59 PM
BarracksSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMaLLDAy050 &raquo;</TD></TR><TR><TD CLASS="quote">I just thought that all Vtec dual cam honda engines have Vtec engagement on both cams.</TD></TR></TABLE>
VTEC is VTEC, but they're not all the same VTEC. Hondata has a concise writeup on the differences between the K20A3's econo-vtec and the K20A2's performance-oriented vtec.
The thing is, all of these i-vtec motors can continually adjust the cam & spark timing and overlap throughout the rev range. These aren't as peaky as the B-series motors. Even the torque curve on mine measured out to be near-flat from 2000 rpm to redline, and that's without any ECU work whatsoever.
Our US-spec EP can be plenty of fun. If you want it to be crazy fast, there are plenty of things you can do. I'd think of it as a modern-day EG hatch.
Old Apr 30, 2006 | 05:54 AM
HAMB0NE's Avatar
Default Re: EP3 K20A3 Vtec Actuation (BarracksSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarracksSi &raquo;</TD></TR><TR><TD CLASS="quote">
. I'd think of it as a modern-day EG hatch.</TD></TR></TABLE>
Hopefully ep's don't get as much attention as eg's. I think they are getting so played out anymore. I'd take an ek/ep over an eg anyday anymore. I'm just tired of seeing the same ones over and over. But done right, i still love them
Old May 2, 2006 | 12:05 PM
Jeenyusss's Avatar
Default Re: EP3 K20A3 Vtec Actuation (EP3surfer)
amen
Old May 2, 2006 | 12:44 PM
JERKSiRcoupe's Avatar
Default Re: EP3 K20A3 Vtec Actuation (Jeenyusss)
nice thread if u get a ep just boost it
Old May 3, 2006 | 06:35 AM
tnhatch03's Avatar
Default Re: EP3 K20A3 Vtec Actuation (JERK ONE)
mines not slow...if that makes you smile...
Old May 7, 2006 | 10:22 AM
hondacrx92's Avatar
Default Re: EP3 K20A3 Vtec Actuation (tnhatch03)
well, ive Just bought a 2002 EP3 Civic Type r, pick it up on Friday, I will let you know what its like next week. I test drove it and can honestly say that the vtec doesnt kick in as aggressive as the old B series motors, but it has tonnes more bottom end power, and still pulls real hard after 6000rpm. I didnt get much of a chance to sink my right foot to the metal, but hopefully soon i will. I would still advise anyone to get one.
Old May 7, 2006 | 05:30 PM
BarracksSi's Avatar
Default Re: EP3 K20A3 Vtec Actuation (hondacrx92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrx92 &raquo;</TD></TR><TR><TD CLASS="quote">well, ive Just bought a 2002 EP3 Civic Type r, pick it up on Friday, I will let you know what its like next week. I test drove it and can honestly say that the vtec doesnt kick in as aggressive as the old B series motors, but it has tonnes more bottom end power, and still pulls real hard after 6000rpm. I didnt get much of a chance to sink my right foot to the metal, but hopefully soon i will. I would still advise anyone to get one.</TD></TR></TABLE>
Lucky bastard, you got what us Yanks are trying to make for ourselves... lol
I'm willing to bet that the "vtec kick" doesn't seem to "kick" so hard because the K-series motors do have more oomph overall. Plus, the constantly-variable cam timing helps to smooth out the torque curve and cam changeover.
I'll tell you what... if you're genuinely disappointed with that motor, I'll trade you mine.
Old May 7, 2006 | 05:52 PM
HAMB0NE's Avatar
I'll tell you what... if you're genuinely disappointed with that motor, I'll trade you mine. </TD></TR></TABLE>
damn you beat me to it!
Old May 8, 2006 | 03:14 AM
hondacrx92's Avatar
lol, I think i will be happy with it.
Old May 8, 2006 | 07:44 AM
LongBeach[DC5]'s Avatar
my brother has a EP3 when i ride in it and he smash on it, it seems pretty slow to me, but he says that it pretty slow too, but its stock just with a air filter thats about it. i got a question can EP3 smoke a tC or GT-S Celica cuz my bro said he smoke both of those but then he raced another tC he lost.
Old May 9, 2006 | 03:38 AM
aneel's Avatar
sup guys i drive an SSM EP and i just noticed the other day if you look really closely around 5k RPM it really does pull a little harder i mean you cant feel it too much but vtec does kick in... im all stock with neuspeed springs... One of my friends owns a 94 LS and i run him all day another one of my friends owns a Corola XRS, most of the times he wins and sometimes i win.. Another one of my friends owns a Matrix XRS and he has never won against me.. i got videos of me racing the Corola XRS and i can get the videos of me racing the other two...LMK if u wanna see em...
aNeeL
Old May 17, 2006 | 05:22 AM
Jeenyusss's Avatar
civic ep3 type r= drool. how much you pick it up for?
Old May 17, 2006 | 01:27 PM
sprint-r's Avatar
Now these roumors are wrong..
I have an EP3 Civic Type-R (200 BHP) and after 6000RPM the VTEC does kick in!
Not so effective like an Integra Type-R VTEC kick but its still brutal.
Definately not a bad engine.. And it has a beautiful sound as it draws the air in. Btw it is totally stock. Get one, you'll like it. (6,7 sec 100km/h)
