Metal? for h23 block on majestic honda
Old Apr 25, 2006 | 07:25 PM
blueBB4lude's Avatar
Default Metal? for h23 block on majestic honda
I am building an h23vtec (no this isnt an h23vtec question) i am workin on making a list of parts i need to order from honda (well hondaautomotiveparts.com) to rebuild the block. in the below diagram for a 94 h23. they label 18-20 as "Metal (no.1)-3"?
Are these bearings for the balance shafts?, i dont remember any bearings if so.
Any help is great, thanks a lot guys
Old Apr 25, 2006 | 07:35 PM
Rosko's Avatar
Default Re: Metal? for h23 block on majestic honda (blueBB4lude)
yeah man those are balance shaft bearings.
prolly dont need replaced either unless there was an oil failure of some kind. theres no pressure on them like the crank and rods so they should be ok.
or if ur gettin rid of the balance shafts you can press those bearings out and put them back in upside down to plug the oil hole.
Old Apr 25, 2006 | 07:39 PM
Default Re: Metal? for h23 block on majestic honda (Rosko)
so thats why i didnt notice them, they are pressed in? thats got to be a delicate process to press new ones in?
Old Apr 25, 2006 | 07:43 PM
Rosko's Avatar
yup.
i turned down some mandrels on a lathe to help press mine out when i flipped them. there are three different sizes i believe.
ESP.net
Aug 19, 2012 05:49 AM
shandonwall
Mar 27, 2009 10:54 AM
pentaq
Jan 10, 2009 03:17 AM
ludesleep
May 8, 2003 09:04 PM
