**FIBERGLASS** Can You /Mould/Bend It With Heat? *hood*
Old Apr 25, 2006 | 04:27 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default **FIBERGLASS** Can You /Mould/Bend It With Heat? *hood*
So Ive got a fiberglass predator hood, got it to fit pretty mint except the very front lip, the part that comes down between the headlights isnt at as much of an angle as the bod line of the car, like 15 degrees off actually, I can push it down itno place (maybe and inch) and it looks ****
Now obviously I cant get it to stay like this
Can I take a butane/brazing torch and heat up the corner of the hood and get it to push down into place without warping /distorting the hood?
I dont care about the paint, its flat black so thatll be easy, but I need this to fit better
Let me know what I can do
Old Apr 25, 2006 | 04:31 PM
kiddcarbuff's Avatar
cut it out, rework more fiberglass into where you exactly want it, if you know how to work with fiberglass you can do it. make sure you have some kind of backing for the glass to rest on white its curing/being applied
Old Apr 25, 2006 | 04:33 PM
lazybrown187's Avatar
Default Re: **FIBERGLASS** Can You /Mould/Bend It With Heat? *hood* (TurblowEF)
I GOT THE SAME PROB
Old Apr 25, 2006 | 04:34 PM
217sportcompacts's Avatar
you can rework it if you have good body skills, or use a heat gun to make it flexible, i wouldnt use a torch
Old Apr 25, 2006 | 04:39 PM
PINKS's Avatar
Default Re: (217sportcompacts)
Theres no chance I cut it off and remake the thing, it fits perfect if I just push it down
I was hoping to heat it up with a butane type torch and would it get flexible enough?
Tips?
Old Apr 25, 2006 | 05:31 PM
PINKS's Avatar
Old Apr 25, 2006 | 06:39 PM
W O T's Avatar
Old Apr 25, 2006 | 08:20 PM
W O T's Avatar
FormulaGSR
Welding / Fabrication
May 26, 2005 07:04 PM
C M S
Dec 11, 2004 03:05 PM
Denny
May 13, 2003 05:09 PM
allmotorEG-SI
Nov 11, 2002 07:41 PM
91SIvic
Oct 18, 2002 06:38 AM
