more frustrating tranny problems
Old Apr 25, 2006 | 04:17 PM
rice a roni's Avatar
Default more frustrating tranny problems
the tranny wont separate from the engine. i've taken all 3 mounts off...supported the engine with a jack under the oil pan...i've got a jack under the tranny and im trying to get the apart but they wont come apart. there is no space to a flat blade screw driver or pry bar in. where to start?
Old Apr 25, 2006 | 04:29 PM
Tippyman's Avatar
Try taking the starter off. It may be held onto the flywheel...
Old Apr 25, 2006 | 04:35 PM
turbinteg's Avatar
Default Re: more frustrating tranny problems (rice a roni)
try to pry evenly on the trans to seperate it with big pry bars
Old Apr 25, 2006 | 04:46 PM
Default Re: more frustrating tranny problems (turbinteg)
the starter is already off....everything that needs to be off is off...i just need to seperate the tranny from the engine. there is nothing to pry on.
Old Apr 25, 2006 | 05:51 PM
bumping..
Old Apr 26, 2006 | 03:21 AM
i also tried jiggling the far tranny mount on the left side.
Old Apr 26, 2006 | 04:16 AM
YasRex's Avatar
Sounds like a mess. Triple check your bolts are off. You may be better off pulling out the entire engine before you damage things prying on the tranny.
Maybe you missed disconnecting something?
Old Apr 26, 2006 | 04:51 AM
paopao's Avatar
Default Re: more frustrating tranny problems (YasRex)
Did you take the flywheel cover off?
Old Apr 26, 2006 | 09:06 AM
Default Re: more frustrating tranny problems (paopao)
i took the two bolts holding the exhaust off and the two of them on the tranny housing but i didnt take the cover off. is that nessecary?
Old Apr 26, 2006 | 10:16 AM
91civichatch's Avatar
There should be about 7 or 8 bolts total holdin the tranny. Did you get the one on the driver side that is somehwere above where the axel goes into the tranny? If you did the try rotating the tranny while pulling at the same time. It'll take some time and muscle but it will come out eventually.
Old Apr 26, 2006 | 10:52 AM
Default Re: (91civichatch)
i'll go recount my bolts when i get home.
Old Apr 26, 2006 | 05:10 PM
Default Re: (rice a roni)
tranny is out...so i need a 12 point 10 mm socket to get the flywheel off?
spens 91 Ef
Mar 2, 2009 04:46 PM
crxpwr1
Sep 23, 2006 12:53 PM
tallblondkid
Aug 11, 2004 01:32 AM
triggerX
Apr 24, 2004 12:03 AM
integraGSR213
Feb 16, 2004 11:19 AM
