Battery Question?
Old Apr 25, 2006 | 10:21 AM
jdmcrx90's Avatar
Default Battery Question?
Ok so i just recently re located my battery to the trunk in my crx. The problem is when the battery is connected in the engine bay it works fine but in the back i have no power to my starter but i have power everwhere else. I don't get it, if anybody can give my some ideas why that would be great.
Old Apr 25, 2006 | 11:36 AM
jdmcrx90's Avatar
anybody?
Old Apr 25, 2006 | 11:47 AM
strictlyimport's Avatar
Default Re: (jdmcrx90)
Might be a dumb question, but is your starter grounded? There is that one little plug that needs to be plugged in.
How did you run your wires? (what size) If you aren't using a larger wire from the battery then to a distribution block and into a couple of smaller gauge wires, you could not be carrying enough current to get your starter to turn. Just let us know.
Old Apr 25, 2006 | 11:51 AM
jdmcrx90's Avatar
I actully have my started grounded twice because i was thinking that, iam using 4 gauge wiring, and i just used my stock battery wire and starter power and connected it to the 4 gauge ran it under my carpet on the drivers side straight to my trunk it was my old batt. wire for my stero
Old Apr 25, 2006 | 10:16 PM
jdmcrx90's Avatar
bump
Old Apr 25, 2006 | 10:21 PM
charlee's Avatar
make sure that the litle black wire that connects to your starter selenoid is conected.if its unpluged your fuel pump starts up but your starter never goes on becuse youre not opening the circuit.
Old Apr 26, 2006 | 01:39 PM
jdmcrx90's Avatar
its pluged in, this is to weird i can not figure it out it is hooked up the exact same as it was under the hood so weird.
Old Apr 26, 2006 | 02:03 PM
saikouEF8's Avatar
why is the starter grounded twice? sumthin doesnt sound right.... i dunno... maybe this will help u? http://crx.honda-perf.org/arti....html
Old Apr 26, 2006 | 02:45 PM
rsca_crx's Avatar
Default Re: (saikouEF8)
power needs to go to the front, then be distributed to both the starter wire and the alternator wire. are both of them hooked to the power from the back?
Old Apr 26, 2006 | 05:00 PM
Crx Jimmy's Avatar
Default Re: (rsca_crx)
run the 4ga directly to the post on the starter and them run a 8ga to the underhood fuse box, you should be good then.
baca00ex
Jun 9, 2011 10:35 AM
steveharrmr23
Sep 14, 2009 11:45 AM
bdmlilburn
May 16, 2009 12:40 PM
91EF919
Apr 6, 2009 08:27 PM
graphic
Dec 9, 2003 07:17 PM
