timing belt @ 60k
Unless you can tell if the belt has excessive wear on it, or you can feel it missing and whatnot, you should be fine waiting to do it until you reach 75k miles. Once you reach 75k, then I would do it.
well, you know about interference engines, don't you???
you can stretch it to the limits stated in your manual... or see link for specifics...
http://www.troublecodes.net/tbelt/hondatb.shtml
what year of accord and what engine?
From 1994-97 the recommeneded change point was 90K for I4 and I believe that the V6 had a chain
from 1998-2002 it was 105K for all engines
I am not sure about the 03- newer cars as I have heard 120K
keep in mind that whatever miles your odometer registers you got to add a lot more,, especially if you do a lot of city driving,, when car is at stop lites or behind traffic engine is still running but miles will not add up,,
75k a good rule of thumb , 6 years if you reside in a very dry . hot climate, AZ, NV. etc etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">what year of accord and what engine?
don't mean to correct you ,, but NO CHAIN , it was a belt as well..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">I am not sure about the 03- newer cars as I have heard 120K</TD></TR></TABLE>
K-series engines (2003+ 4-cyl) uses a timing chain. I don't know about 2003+ V6...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">
v6 is still a belt in 2003
What do u suggest me doing... to find the problem.. and what kinds of problems am i looking @...i replaced the belts and timed the engine... but im sure something isnt gonna work right.
When the timing belt breaks, the pistons can come up and hit the valves. You could have bent valves, or worse. Depends how fast the engine was turning when the belt broke.
Hmm.... guess ill kno when i go to put it in...i hear the head could also be warped...? man the motor was $420 with 86,000 miles on it.. and i only payed $200... so if it works cool...i doubt it but if not... H22 baby...:-)
Nah... im good i'd be better off just swapping in the H22.. there isnt enuff knowledge around to do that kind of swap and i dont have the equipment for any kind of the machine work that takes... and yeah.. i def got ripped...
1yesfan
Mar 11, 2015 07:54 PM
drew2
May 9, 2008 06:12 AM
