Pulled tach needle off to clean...Now it doesn't work?
Old Apr 25, 2006 | 04:42 AM
Ding's Avatar
Default Pulled tach needle off to clean...Now it doesn't work?
I am selling my car finally and I decided to clean out everything in the car. So I took off the speedometer needle, cleaned it, and it was fine. I then took off the tach needle, cleaned it, and now it won't move. I noticed that there is a spot where the needle gets harder to push. I guess this would normally be around 8 grand, to stop it from going all the way around? Well anyway, I don't want to take my car to any shop, as they all suck, so how can I fix this? Thanks.
Old Apr 25, 2006 | 04:53 AM
wood 1's Avatar
Default Re: Pulled tach needle off to clean...Now it doesn't work? (90CRXLS)
best bet would be to get a donor cluster andswap out the tach.
Old Apr 25, 2006 | 04:54 AM
YasRex's Avatar
Got to fix your cluster?
If the problem isn't obvious you prolly need to buy new tach gauge. You dont have to get the whole cluster. they are pretty cheap
Old Apr 25, 2006 | 06:29 AM
Ding's Avatar
Default Re: Pulled tach needle off to clean...Now it doesn't work? (YasRex)
Well does anyone have a cluster they want to sell me or know where I can get just the tach gauge at?
Old Apr 25, 2006 | 06:59 AM
Ding's Avatar
Bump I need to fix this now.
Old Apr 25, 2006 | 07:06 AM
Jonknee's Avatar
Same thing happened to me, i went to pick n pull , i took off the speed gauge, and he said " you destroyed the complete cluster so you have to pay for the whole thing"
30 bux anyway.
Old Apr 25, 2006 | 07:10 AM
Ding's Avatar
Default Re: Pulled tach needle off to clean...Now it doesn't work? (La-quiete)
Well the speedometer works. I pulled it off and everything is all good. What can I do? Anyone fix this problem?
Old Apr 25, 2006 | 07:35 AM
wood 1's Avatar
Bite the bullet, go to a junk yard, get a cluster and awap out tachs.
Old Apr 25, 2006 | 08:00 AM
Ding's Avatar
Default Re: Pulled tach needle off to clean...Now it doesn't work? (wood 1)
I will, I just need to know how exactly to "swap out the tachs." Everyone keeps telling me to do this, but no one will tell me how. Also can I use a tach from any civic or does it have to be a crx?
Old Apr 25, 2006 | 08:17 AM
Ding's Avatar
Bump.
Old Apr 25, 2006 | 10:51 AM
wood 1's Avatar
Civic tach will work, remove clear plastic cover, turn cluster over, find mounting screws and remove, tach will come right out. Installation is reverse of removal. It is actually pretty easy, you do know how to remove the cluster from the dash I am guessing.
t_can
Jul 27, 2016 07:06 PM
djjsc
Mar 24, 2012 03:38 PM
yellowxhoodie
Sep 4, 2009 06:19 AM
Mike"IAMSLOW"Myers
Sep 16, 2007 09:42 AM
Mugenkid
Dec 21, 2004 09:07 AM
