Suspension & Brakes Theory, alignment, spring rates....
compatibility with illuminas and progress springs.
Old Apr 25, 2006 | 12:28 AM
SF_EF8's Avatar
Default compatibility with illuminas and progress springs.
tried searching numerous times could find the specific setup up, i new to what is TOO stiff or soft for certian shocks.
i'm debating right now on getting a set up tokico illuminas, i have a set of progress springs on my crx with a b16a in it. springs advertise about a 2.3 inch in the front and 2.0 inch in the rear. i was debating on just getting a d2 damper or a tein basics.
i use the car for everyday driving, houston, tx.
only thing i do a lot is straight line racing, of course i love to hit the corners hard everynow and then. i do an occasional autocross here and there. not a lot though.
i just want something that has really good handling and a comfortable yet sporty ride, illuminas sound alright?
or should i start looking for a damper?
thanks in advance.
Old Apr 25, 2006 | 08:05 AM
Tyson's Avatar
Default Re: compatibility with illuminas and progress springs. (SF_EF8)
illuminas will be great for you.
Old Apr 25, 2006 | 08:24 AM
SF_EF8's Avatar
Default Re: compatibility with illuminas and progress springs. (Tyson)
cool so i won't have a problem with them with the drop i have or the spring rate of the springs?
Old Apr 25, 2006 | 08:29 AM
Tyson's Avatar
no shock is going to give you any difference in lowering capability, unless you got some shortened shock modified, which is bucks. but youll be fine as long as you keep half your bumpstop.
extended top hats are always available. illuminas can be modified to be lower in the shock fork as well. it goes without saying, that will void the warranty tho.
https://honda-tech.com/zerothread?id=469485
you have nothing to worry about the stiffness of the spring. illuminas are a quality shock. the adjustment available will allow you to tune the ride and adjust quickly.
Old Apr 25, 2006 | 08:38 AM
SF_EF8's Avatar
any place i could pick up bumpstops, brand new?
what exactly do extended top hats do?
Old Apr 25, 2006 | 10:43 AM
Tyson's Avatar
Default Re: (SF_EF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SF_EF8 &raquo;</TD></TR><TR><TD CLASS="quote">
i noticed you edited your question....amazing what reading does, answers your own questions, huh.
tokico illuminas come with new bumpstops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
what exactly do extended top hats do?</TD></TR></TABLE>
they give you back shock travel, which is (one of) the problem(s) with lowering.
d16z6Tcrx
Sep 21, 2013 09:54 AM
bikerballrEM2
Mar 31, 2008 03:19 PM
98savage
May 1, 2007 10:03 AM
vermilion
Suspension & Brakes
Aug 1, 2006 01:14 AM
chron1k
Oct 17, 2002 03:23 PM
