Parking/Tail/Interior Dash lights dont work.... fuses all good... why?!
Old Apr 24, 2006 | 09:19 PM
shawn.hayden's Avatar
Default Parking/Tail/Interior Dash lights dont work.... fuses all good... why?!
like it says, all of the lights listed dont work, and the "Small Light" fuse which is the fuse for that circuit is fine.... what else could it be?
I've also changed the Dimmer and Headlight switch's....
Old Apr 24, 2006 | 09:38 PM
YeuEmMaiMai's Avatar
Default Re: Parking/Tail/Interior Dash lights dont work.... fuses all good... why?! (shawn.hayden)
MultiPlex Unit needs to be tested
Old Apr 24, 2006 | 10:05 PM
pos_cd5's Avatar
check EVERY fuse...and replace the blown ones...even if it doesnt fix it atleast you probably fixed something else, hahahahaha....
Old Apr 24, 2006 | 10:12 PM
Default Re: Parking/Tail/Interior Dash lights dont work.... fuses all good... why?! (pos_cd5)
no fuses are blown and I changed any/all fuses that COULD be the problem for safe messure....
Old Apr 25, 2006 | 03:58 PM
bump
Old Apr 25, 2006 | 04:56 PM
accord-pro's Avatar
I see that on your signature you say that the H22 is coming very soon.....i am glad for you ....
Well,,, so is my crystal ball .. it is on backorder,, SO why don't you tell us what year and model you have , it might make helping you a bit easier ...
Old Apr 25, 2006 | 05:12 PM
delslowhonda's Avatar
by any chance have you had your guage cluster out recently? seems like way back when i had an accord, and my guage cluster was removed from the car no lights would come on either. maybe you forgot to plug something back in, or pinched a wire or something? or maybe i'm just an idiot? lol just trying to help
Old Apr 27, 2006 | 08:32 PM
Default Re: Parking/Tail/Interior Dash lights dont work.... fuses all good... why?! (delslowhonda)
its a 93 LX, and they just stopped working... I'm about to just tear into it and try to find the problem that way, I'll have to bum a ride though
Old Apr 30, 2006 | 06:02 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Parking/Tail/Interior Dash lights dont work.... fuses all good... why?! (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">MultiPlex Unit needs to be tested</TD></TR></TABLE>
Come on man I would have expected better of you.
But if you've checked fuse 23 and are sure it's good then your next move would be to test the headlight switch it looks like.
Old Apr 30, 2006 | 06:15 PM
Default Re: Parking/Tail/Interior Dash lights dont work.... fuses all good... why?! (MooGoCow3)
those units are known for causing these type of problems. I frequent another forum and there are multiple instances where that little control box fails causing interior / excterior lifghts not to work properly....
Old Apr 30, 2006 | 06:31 PM
fw190bvi's Avatar
this is gonna seem really odd but....
are the corner lights (the corners, either the clears or the orages) burnt out on either side?
Old Apr 30, 2006 | 06:59 PM
Ross 2.0's Avatar
Multiplexes didn't show up in accords til '98
Old Apr 30, 2006 | 07:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">Multiplexes didn't show up in accords til '98</TD></TR></TABLE>
he didn't say what year
so I made a quess
Original post:
Parking/Tail/Interior Dash lights dont work.... fuses all good... why?! 12:19 AM 4/25/2006
Old May 1, 2006 | 05:16 AM
Ross 2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">he didn't say what year
so I made a quess
Original post:
I've also changed the Dimmer and Headlight switch's....</TD></TR></TABLE>
Well you know what happens when you <U>***</U>ume
Old May 1, 2006 | 06:52 AM
accord-pro's Avatar
like it was sugested by MOO, chk fuse # 23 underhood fuse box,, if ok,,,,,
you need to chk if you are getting power at red/green wire going into the combo switch,, if so,, turn switch on and chk for power at RED/BLACK wire, if no power and you had power on red/green you got a bad switch,
if no power coming in to switch at RED/GREEN you got bad wiring from fuse box to switch ..
cleanda6
Oct 29, 2011 09:08 PM
vteck1ck
12
Feb 17, 2010 08:04 AM
slob20ef
Mar 30, 2009 05:43 PM
legendisdope
Jan 29, 2007 07:17 PM
4G63T
Feb 3, 2006 09:51 AM
