help solve this idle problem (searched)
Old Apr 24, 2006 | 08:12 PM
bleedblue94's Avatar
Default help solve this idle problem (searched)
well im at a loss on this one. car starts fine and idles pretty well at cold start...only a little putt putt can be heard in the exhaust. then once it warms the idle suddenly drops, then starts to climb slowly, goes to where it should be then drops again...each time it seems like its going to staul and eventually does. car seems to run fine the rest of the time. also once it stauls i hear a humming from the iacv, when i unplug it the hum stops, then when i plug it in again it clicks and humms again. once i turn the ignition off and turn it back in the on position again the humming is gone.
ive measuresd the voltage during idle and it holds steady at 14.5 volts and drops to 13 when the idle drops.
also measured the map sensor voltage and it reads 1.09 - 1.23 volts when warming up, then .90 - .93 volts then begins to fluctuate with the idle as expected between 1.50 - .90 volts
i also pulled the plugs that i recently put in and dont really see anything at all
cylinder 1
http://www.imagestation.com/pi...3.jpg
cylinder 2
http://www.imagestation.com/pi...0.jpg
cylinder 3
http://www.imagestation.com/pi...6.jpg
cylinder 4
http://www.imagestation.com/pi...c.jpg
this fluctuation is kind of drawn out in its cycle...not fast paced like a vacuum leak. also this is an obd2 b18b running off an obd1 p75.
ive tried new dizzy, map sensor, checked tps, clean iacv....just getting frustrated
Old Apr 25, 2006 | 05:54 AM
Default Re: help solve this idle problem (bleedblue94)
forgot to mention i have a b16 tb on this motor so its not the fitv
Old Apr 25, 2006 | 09:45 AM
kg;buobuos;uot
Old Apr 25, 2006 | 05:42 PM
today i did plugs, wires, replaced fpr, bled coolant, tried a 3rd iacv, did timing, replaced map sensor, tested tps
still same problem
Old Apr 25, 2006 | 09:11 PM
hondastrtracr's Avatar
Hey bro got a similar problem... only its when warming up then seems to settle when warm but still does when i hit the gas in park or nuetral to rev it a little. I did everything u did and more and am waiting for a new ecu to see if that helps... right now it wont even start after the car is warmed up. Do 99's have a main relay if so where is it (sorry for the dumb question)
Old Apr 29, 2006 | 05:32 PM
ok here is the latest...i have gone over everything at this point, then today going on someones suggestion i unplugged the o2 sensor. the idle problems all seemed to go away. only problem i had was when i got off the gas all my lights would dim noticably and when i was driving and pushed the clutch in and stopped at a light the car let the idle drop to much and died. wondering if the problems could stem from someting not regulating the voltage of the electrical system? or from a faulty o2? do o2s go bad without throwing a code?
Old Apr 30, 2006 | 10:25 AM
also does anyone know why the secondary o2 sensors ground wire, signal wire, and heater wire all run into the car harness.....i was checking some things and found that on the 98 ex harness these wires go to the ecu, but also run to the green plug on the engine harness that plugs into the car harness.....wondering why???
Old Apr 30, 2006 | 04:32 PM
Hey I been having similar idle problems but have yet to get to the o2 sensors... It will not run right when warm and is pissin me off. Your more then welcome to hit me up on aim at-> hondastrtracr and we can talk about our issues. There seems to be no particular answer when it comes to these problems maybe we can figure it out and put a stop to the "shitty" idle problem. I have replaced almost every thing except for the o2's and the fuel pump! Damn it's gettin expensive but my car will be new in the end!
Old May 5, 2006 | 01:24 PM
so i was watching the fuel pressure today when the motor stalls..and i noticed that just as it dies the pressure shoots up to that of wot....so i then removed the hose from the fpr to the im and i plugged the im hole and left the fpr one open, so the car was getting more pressure at idle.....and it seems to stop the problem.......
i have tried 2 other fpr and i have the same problems when everything is hooked up so im wondering if this could be a sign of a fuel pump dieing or what.....pressure is coming up just how it should according to a helms at idle ut likei said when i trickthe fpr to think it runig wo he ca ems to dle fine.....any advice??? btw there is a enom fuel pump on this car
Old May 6, 2006 | 09:07 PM
im wondering if its the alt bc last year my old one died and i needed the car the same day....no parts stores had any and then i got one, but it wasnt for my car...they gave me the wrong one, but i had no choice so i grinded out the mount holes and got it to fit and such and ran it like that....but im wondering if even since the alt was for another honda motor if the voltage regulator is different....i have a feeling the guy at the shop gave me a d series alt, but im not sure....in any event the plug fits perfect, but im still having the idle problems and im trying to figure this all out....so far this is the only thing i can think of that i have transfered from the old motor to the new motor that could be causing this.;....and i honestly cant remember if this started at the same time as i changed the alt last year
Old May 6, 2006 | 09:23 PM
b18sihatch's Avatar
i had a friend who had the exact same problem he couldnt figure it out for ****. i went over and he drove it around the block with me in the car to get it to do it, we pull into a parking lot, let it idel and sure enough it would idel up to 1,500rpm then down to 500rpm then over and over and over. i went and unplugged the tps. and the idel surging stopped. but you said that you have already looked at that. but it was having the exact same problems you listed. it was weird tho bc you would think that if the tps was plugged in that it would do the idel surging and then would still do the idel surging when unplugged, but sure enough it stopped when unplugged.......i know this doesnt sound too relivant, but he had the exact same problems.... you might wanna if you have another throttle body that is completely stock go ahead and put it on, and see if you have a faulty tps....
bleedblue94
65
Nov 7, 2006 08:36 AM
bleedblue94
28
Sep 11, 2006 12:55 AM
bleedblue94
Jun 25, 2006 01:58 AM
bleedblue94
May 6, 2006 09:04 PM
mikeunreal2
11
Mar 23, 2006 12:00 PM
