Rear LCA bushing
Ok I've had a set of GSR lcas laying around for a while and decided to attempt to burnout the bushing(it was rotting anyways). I got everything removed except the metal sleeve around the rubber. I've tried sawing & chiseling the thing out with no luck. I just want to through the new ES ones in there so I can run a rear swaybar finally, but these sleeves are a pain in the ***.
Modified by broketuner-egb16a at 9:29 PM 4/24/2006
Are you sure the sleeves need to be pushed out? Some of the ES bushings just require the removal of the rubber, and then the poly bushing presses inside the remaining sleeve.
If the sleeve must come out, here is what you can do:
-Insert a hacksaw blade through the bushing hole (where you burnt the rubber out)
-Attach your hacksaw to the blade
-Cut your way through one spot on the sleeve so it is no longer a complete ring
-Chissle ring out starting from your cut
-The ring should fold up at the cut & eventually come out
-Be carful not to damage the LCA
all but the trailing arm bushing, the sleeve needs to come out. your method is the usual method.
i would have prefered to push the whole bushing out complete.
drsab2000
Mar 1, 2013 04:48 PM
91GEDHATCH
May 18, 2011 06:23 AM
My JDM EJ8
Jul 9, 2008 06:05 AM
