Shaking at 60
I just bought a 94 civic hatchback just my luck it came with the front springs cut to ****.. like i literally had to put rubber spacers in the springs just so the tires dont rub.. the car runs fine the only probably is when i reach 60 mph the cars shakes really bad no im thinking its the shitty suspension with well basically no travel at all since i bottom out on everything but i was wondering if it could possibly be something else im not really sure to look for so can someone please fill me in thank you....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by void_accord »</TD></TR><TR><TD CLASS="quote">wheels are off balance</TD></TR></TABLE>
my car did exact same thing. go balance your wheels
There could be alot of things at work here. I would fix the suspension first before tracking down issues. You can feel alot of shake and bounce with a very stiff suspension, and when you have to put spacers in to counteract rub, it could make it worse.
Thank you everyone for your input.. ill change the springs and then if it doesnt help ill remember to check the alignment if i run into anymore problems ill let you know thank you all again for the extra help
if its not the wheels, it could be the tie rod balljoint. you can usually check it by jacking the front wheels in the air and trying to tilt them with your hands, if it feels like somthings loose, thats probably it.
yup definately the wheels need to be balance...mine did it once i hit 80 on the freeway....good thing, cuz i didn't need to be going any faster than that....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">sorry to thread jack, but what if this is happening under harder braking? </TD></TR></TABLE>
Your rotors are warped! Better go get some new discs because sooner or later you wont be able to brake. Happened to me on the highway and drove car home like so. Replaced rotors half hour after and shaking under braking left.
front end vibration can be front end parts( balljoints, tie rods etc.) wheels bent or out of balance or in need of hub centric rings if aftermarket wheels are on your car. you need to get those spacers off your car. fix the suspension problems. and dont bother with an alignment if the tires are almost worn. if you have half tread left and they are worn evenly across then go ahead and have it aligned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacinThug »</TD></TR><TR><TD CLASS="quote">Your rotors are warped! Better go get some new discs because sooner or later you wont be able to brake. Happened to me on the highway and drove car home like so. Replaced rotors half hour after and shaking under braking left.</TD></TR></TABLE>
yeah but he said that the car shakes when he's hitting speed, not slowing down...but yeah i know what your saying, my car shook like crazy, i bought new rotors thinking they were warped, and when i got them replaced lol, they just had to be cut...but yeah...check that too, if it shakes when you break..
SYNSEI
May 19, 2007 03:41 PM
