Help with ECU Codes and Hesitation
Old Apr 24, 2006 | 06:28 PM
Deviation's Avatar
Default Help with ECU Codes and Hesitation
I'm having some issues with my 91 Civic (std w/ D15B2, PM5 ECU, 4spd tranny). The guy before me put the D15B2 in. I put the PM5 in. I should also mention that it only has a header on it. The rest of the exhaust isn't attached.
It has a CEL on right now. So I did the check for ECU codes. I got 8 short blinks followed by 19 short blinks.
Code 8 is the TDC Sensor. I have some ideas on what to try for this tomorrow (thanks to https://honda-tech.com/zerothread?id=468260 ). Any ideas on what the TDC Sensors go for?
Code 19 is the Automatic Lockup. But I have a manual? Any ideas on this one? The ECU code is PM5-A560 if that matters. This one kinda boggles me.
The car idles ok. You can rev it up ok in neutral (though it has some hellacious back fire & flames). The problem is when you are moving. When I get to about 10MPH ins first, the car starts to bog real bad. If I shift to 2nd, the car is ok for another 10MPH or so. I'd tell you the RPMs, but I don't have a tach.
Any ideas?
Old Apr 24, 2006 | 06:34 PM
Tippyman's Avatar
Default Re: Help with ECU Codes and Hesitation (Deviation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deviation &raquo;</TD></TR><TR><TD CLASS="quote"> Any ideas on what the TDC Sensors go for? </TD></TR></TABLE>
I believe you have to get the whole dizzy. sorry i went through the same thing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deviation &raquo;</TD></TR><TR><TD CLASS="quote">Code 19 is the Automatic Lockup. But I have a manual? Any ideas on this one? The ECU code is PM5-A560 if that matters. </TD></TR></TABLE>
You need a PM9 ECU. That's what came with my 91 Std. (4 speed.)
I have one for sale! check the sig!
Old Apr 24, 2006 | 06:36 PM
Deviation's Avatar
Default Re: Help with ECU Codes and Hesitation (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
I have one for sale! check the sig!</TD></TR></TABLE>
PM9 is for the D15B1. I have the D15B2 (DX motor) which uses the PM5.
Old Apr 24, 2006 | 06:46 PM
Tippyman's Avatar
Well, I had a 91 Std. and that's what it came with. I didn't think u swapped, lol.
I guess you got an auto computer? are they the same code?
Old Apr 25, 2006 | 04:40 AM
Deviation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I guess you got an auto computer? are they the same code?</TD></TR></TABLE>
That I don't know. I thought they were.
Old Apr 25, 2006 | 08:41 AM
jlicrx's Avatar
37820-PM5-A560 is automatic ECU
Old Apr 25, 2006 | 08:44 AM
Deviation's Avatar
Default Re: Help with ECU Codes and Hesitation (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">37820-PM5-A560 is automatic ECU</TD></TR></TABLE>
Son of a.... So what's the code for the manual?
I should still be able to drive with it right? Will it cause any issues (other than the cel)?
Old Apr 25, 2006 | 08:52 AM
Deviation's Avatar
Would the manual ECU be PM5-A060? Or is it the first number I need to look for (37820)?
This one says its from a 5spd and has the A060 number.
Old Apr 28, 2006 | 09:47 AM
Deviation's Avatar
So I fixed the TDC sensor code. The plug was barely in the socket. Plugged it in & reset the EC uand it was gone. So I figured I'd try to drive it. It still hesitates a lot when I get to about 10MPH in 1st and 20MPH in 2nd no matter how easy I am on the gas.
Is there something else I can look at? I haven't put in the other ECU yet, but I didn't figure that would cause this issue. Ideas?
Old Apr 28, 2006 | 06:55 PM
Deviation's Avatar
Got my gauge cluster in so I should be able to tell what RPMs this thing falls flat on its face tomorrow.
Old Apr 29, 2006 | 05:09 PM
Deviation's Avatar
Definately distributor. I took the cap off and immediately noticed something. The shaft that the rotor is on had some serious play in it.
These things aren't cheap! Local parts shops want at least $180 for one.
Old Apr 29, 2006 | 05:31 PM
SVOboy's Avatar
I've got a spare d15b2 dizzy and manual pm5,
SolScifen
May 19, 2013 11:35 AM
jesiaczek
Jan 26, 2012 03:31 PM
ef_you_again
Mar 17, 2005 11:14 PM
Brewer
Jul 7, 2004 01:49 PM
ZCHF
Jun 15, 2003 09:47 AM
