VC rubbing hood...b18c in a 95 Coupe
Old Apr 24, 2006 | 06:23 PM
TaylorEj1's Avatar
Default VC rubbing hood...b18c in a 95 Coupe
I picked this car up about a month and a half ago and just noticed that part of my valve cover looks like it had been rubbing the hood, then I look at the hood and yep, it's definitely been rubbing. It's done it so much that that part of my hood is now indented.
The car is using stock 94 Integra mounts. I've got mount inserts on the way, is that going to change anything?
I'm painting my valve cover soon and don't want it to expletive up again because it's rubbing.
Thanks.
Old Apr 24, 2006 | 06:30 PM
Padawan's Avatar
Darth ModerVader
Default Re: VC rubbing hood...b18c in a 95 Coupe (TaylorEj1)
Is it rubbing on the hood skin, or the reinforcing skeleton?
Old Apr 24, 2006 | 06:32 PM
TaylorEj1's Avatar
I guess it would be the skeleton.
Old Apr 24, 2006 | 06:51 PM
TaylorEj1's Avatar
TT
Old Apr 24, 2006 | 06:53 PM
Padawan's Avatar
Darth ModerVader
Default Re: (TaylorEj1)
Have you considered removing or reshaping the section that is rubbing?
Old Apr 24, 2006 | 07:00 PM
TaylorEj1's Avatar
I've considered cutting that part out but I dont want to expletive it up. It's a ViS double-sided CF OEM hood.
Old Apr 24, 2006 | 07:20 PM
Padawan's Avatar
Darth ModerVader
I had a strong suspicion it was a VIS hood. If I recall correctly, certain versions of the hood did indeed have clearance issues with swapped engines. If you <u>carefully</u> remove the offending area with a Dremel, you should be fine.
Old Apr 24, 2006 | 07:33 PM
TaylorEj1's Avatar
Alright thanks.
AK_CRX
87
Apr 25, 2012 10:34 AM
Krisgh15
Apr 4, 2006 07:07 PM
foam
Dec 29, 2005 11:55 AM
Jerod
Jul 9, 2004 03:17 PM
Black R
Jan 29, 2004 03:50 AM
