CRANK TIMING!! - Cant See The Markings - How- To Fix?
Using a old old old stock oem d16a6 crank pulley
The lines are pretty much non existant, i kdont know what they look like stock but I can barely see mine when Im 2-3 inches from it, they just look like little chips or something
Should I take a paint marker and repaint them? Will it mess with anything? hurt anything?
I just did a rebuild and wanna start it up and have never touched honda timing before, what should I do?
Thank
Thank
take your spark plugs out, stick a long *** screw driver in the #1 cylinder, rotate crank pulley until screwdriver is at highest point (aka top dead center). There should be a little arrow on your block right next to the crank pulley, so mark it there on your pulley once at TDC
Xemu
28
Apr 22, 2007 01:56 PM
iperez
Jun 24, 2004 06:58 AM
DOHC_C-REX
Mar 24, 2004 11:51 AM
