What causes this?? Bearing Carnage
Old Apr 24, 2006 | 05:04 PM
josh green's Avatar
Default What causes this?? Bearing Carnage
my friend took his car to the track and made one good pass, then the next pass, started knocking. it didnt break up or detonate going down the track nothing abnormal sounding or feeling. on return road is when he started hearing it. these are OEM honda bearings. 650whp. but more like 450 on this pass. low boost. Spun about 1/4 of the way. didnt damage the crank, just put some black marks in it that have already been polished out. New rods and bearings going tomorrow.
[IMG]
Modified by josh green at 6:23 PM 4/24/2006
Old Apr 24, 2006 | 05:21 PM
stizzit's Avatar
Default Re: What causes this?? Bearing Carnage (josh green)
i'm interested to see the crank, got any pics??
thx.
Old Apr 24, 2006 | 05:23 PM
josh green's Avatar
Default Re: What causes this?? Bearing Carnage (stizzit)
the crank looks like it did when he installed the rods except it was tinted. He already polished that ****, took about 2 minutes.
Old Apr 24, 2006 | 05:44 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh green &raquo;</TD></TR><TR><TD CLASS="quote">the crank looks like it did when he installed the rods except it was tinted. He already polished that ****, took about 2 minutes. </TD></TR></TABLE>
Have you measured it? The last one I did this to looked fine, but was undersized by almost .010".
Old Apr 24, 2006 | 06:13 PM
SPOOLINmatt's Avatar
Default Re: What causes this?? Bearing Carnage (Jim Truett)
this has happened before, i think the rod was fucked up after that and caused this again. teh first time, it remeasured fine and clearanced fine too. new rods going in. the surface of the crank did not even get scratched.
Old Apr 24, 2006 | 07:35 PM
postman's Avatar
Default Re: What causes this?? Bearing Carnage (SPOOLINmatt)
improper clearances or no oil travel in there, maybe forgot assembly lube
Old Apr 24, 2006 | 08:27 PM
Default Re: What causes this?? Bearing Carnage (postman)
i didnt forget assembly lube, if the motor ran for a few months already, assembly lube had nothing to do with it. brand new oil pump as of 3 weeks ago. but my old one was going bad causing some bearing rattle, it could have jump started this problem. Clearances were well within spec.
Old Apr 25, 2006 | 04:48 AM
Cuda70's Avatar
Looks like improper oiling to me.
Old Apr 25, 2006 | 06:16 AM
tgreaves's Avatar
Default Re: What causes this?? Bearing Carnage (Cuda70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuda70 &raquo;</TD></TR><TR><TD CLASS="quote">
Looks like improper oiling to me. </TD></TR></TABLE>
I agree, It surely got hot.. Put another bearing in and plastigauge it, if its in spec then just go with it..
Old Apr 25, 2006 | 04:35 PM
NJcoupe's Avatar
Default Re: What causes this?? Bearing Carnage (tgreaves)
Improper oiling, lack of oil, incorrectly sized bearings.
Old Apr 28, 2006 | 09:52 AM
Iceman05's Avatar
oil starvation...
Old Apr 28, 2006 | 02:53 PM
Runnerdown's Avatar
Default Re: What causes this?? Bearing Carnage (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">Improper oiling, lack of oil, incorrectly sized bearings.</TD></TR></TABLE>
yes, and do NOT reuse the crank with that much bearing damage or you will be wasting time and money.
GReddy SI
Jun 6, 2012 09:31 PM
ShortbusEK
Mar 7, 2008 01:29 PM
ls19integra95
Feb 20, 2007 03:42 PM
mike93eh
Jan 12, 2006 07:27 PM
cltitus
Oct 30, 2005 10:23 AM
