High Output Alternator.
Old Apr 24, 2006 | 05:01 PM
Slacker87's Avatar
Default High Output Alternator.
Does anyone know where i could get one. I've posted this a couple of times with no real answers. I have a 120 amp sound system and our stock alternators have only 60 amps. Has anyone fabricated a different mount for a different alternator. Help me out please i dont want to get rid of my two 10's i dont think that's an insane sound system. I have 3 capasitor batteries. Everyone tells me it should be working i just dont have a big enough alt. ANY HELP MUCH APRECIATED
Old Apr 24, 2006 | 05:24 PM
WolfGod's Avatar
Default Re: High Output Alternator. (Slacker87)
ebay, they have stock alternators rewound for upto 160 amps i think, i was looking at them earlier because im running about 6000WRMS, but i'll be putting it off since my system takes up alot of space and is unneeded weight with gas how it is
Old Apr 25, 2006 | 04:57 AM
Slacker87's Avatar
Default Re: High Output Alternator. (WolfGod)
they only put out 60 amps at idle though, read the fine print. Someone has to know i mean i cant be the only one with a sound system in a Crx
Old Apr 25, 2006 | 05:11 AM
YasRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slacker87 &raquo;</TD></TR><TR><TD CLASS="quote">they only put out 60 amps at idle though, read the fine print. Someone has to know i mean i cant be the only one with a sound system in a Crx</TD></TR></TABLE>
If you ask me, you have another problem.
Old Apr 25, 2006 | 07:38 AM
91civichatch's Avatar
yea ebays a good placee to get the high output alternator. I got mine off of there from a campany called load boss. It puts out 170 amps and 60 amps at idle. Even though it's just 60 at idle that's better than stocks alternator at idle. If that still doesn''t work for you you can always jus give a little gas and raise the rpm to 1500 where it starts to put out 170
Old Apr 25, 2006 | 07:51 AM
WolfGod's Avatar
Default Re: (91civichatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civichatch &raquo;</TD></TR><TR><TD CLASS="quote">yea ebays a good placee to get the high output alternator. I got mine off of there from a campany called load boss. It puts out 170 amps and 60 amps at idle. Even though it's just 60 at idle that's better than stocks alternator at idle. If that still doesn''t work for you you can always jus give a little gas and raise the rpm to 1500 where it starts to put out 170</TD></TR></TABLE>
this guys head is in the right place
what kind of system do you have that needs 120amps at idle?
B16A CRX
Audio / Security / Video
Aug 22, 2007 01:40 PM
draperj09
Sep 26, 2006 12:34 PM
Slacker87
11
Apr 26, 2006 11:57 PM
hawado
Jul 5, 2005 07:35 PM
CrazyModGSR
Jan 14, 2005 06:12 PM
