T-belt has nicks on it
Old Apr 24, 2006 | 03:05 PM
Voodooboy520's Avatar
Default T-belt has nicks on it
Pics are worth a thousand words
Rubbing against something? Its an Advance belt, so I woudlnt doubt it being deffective or something. I cant think of what would do this though.
Old Apr 24, 2006 | 03:06 PM
Pee Wee's Avatar
Default Re: T-belt has nicks on it (Voodooboy520)
oem honda for piece of mind
Old Apr 24, 2006 | 03:08 PM
Yeah, I totally forgot when I bought it. Was a bit nervous at the time.
Old Apr 24, 2006 | 03:13 PM
Pee Wee's Avatar
Default Re: (Voodooboy520)
yeah thats something you cant skimp on
Old Apr 24, 2006 | 03:16 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: (Pee Wee)
What's wrong with an Advance belt? What about Advance water pump? =\ As long as you do the change at the 60k marks, it should be fine... right? Who's had a correctly installed Advance snap before 60k?
Old Apr 24, 2006 | 03:21 PM
Pee Wee's Avatar
Default Re: (phoenix_iii)
like i said "peace of mind" i never said it will
Old Apr 24, 2006 | 03:24 PM
So what do you guys think, are they stretch marks?
Pee Wee's Avatar
how do the teeth look?
Old Apr 24, 2006 | 03:31 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Make sure that your idler pulley bearing isn't frozen or going bad. Take this warning seriously or suffer the consequences.
Old Apr 24, 2006 | 03:37 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
It looks like it is rubbing at a certain spot on the cover,
if so,the cover should be marked as well..
The only place the outer surface of the belt makes contact
is at the tensioner pulley..
If the pulley bearings were going bad,it might create a
drag/fricton there and scar the belt,So check that too..
Old Apr 24, 2006 | 03:38 PM
user 72830283's Avatar
yea i would only replace such vital parts with OEM specified parts...
like pee wee said:
"peace of mind"
Old Apr 24, 2006 | 03:39 PM
I'm stupid, I had the belt off to do my front main last month. I didnt replace the pully, but the belt has about 350 miles on it.
Old Apr 24, 2006 | 04:14 PM
EF9ZC's Avatar
On my zc i changed belt like 3 times and it always looked like that, i'm not saying its bad or not i'm just saying thats how mine always ended up looking
Old Apr 25, 2006 | 10:28 AM
Default Re: (EF9ZC)
Yeah I definatly remembered something last night. When I last put the belt on, I forgot to put tension on the belt and started it. It scared the **** out of me, but it was flapping around. Thanks for the help
Old Apr 25, 2006 | 12:56 PM
EJ1 wilcox's Avatar
Nice work
At least you caught it before it became a problem. I wore the teeth almost flat on my timing belt in two months because it was too loose. Good thing I caught it before it snapped!
How did you tension it? I used the "hanger" method, and it's working out great.
Old Apr 25, 2006 | 01:59 PM
I put tension on it per the worshop manual's instructions - get it on and everything then turn the engine over 90 degrees counter clockwise, then tighten the tensor.
tmessenger
Jun 14, 2010 05:58 PM
Legion
Nov 23, 2007 07:45 AM
duncan
Nov 12, 2003 11:15 AM
af97civic
Jun 10, 2003 01:31 PM
Neeko
May 4, 2002 12:41 AM
