headgasket?
Old Apr 8, 2002 | 12:18 PM
B_CRUZ!'s Avatar
Default headgasket?
how bad will it f_ck up reliability if i just use 1 or 2 layers of the OEM head gasket. i'm thinking since my motor is apart now i might-as-well... has anybody here done this? what are the cons of it?
thanks for the help HONDA-TECH!
Old Apr 8, 2002 | 12:22 PM
Spade's Avatar
Default Re: headgasket? (B_zurC)
Cons = Can mess up timing. Rumor.
Shrug.
Old Apr 8, 2002 | 12:41 PM
erniecars's Avatar
Default Re: headgasket? (Spade)
Pros = Increases Compression.
Amount depends on your motor.
Take out the middle layer of the head gasket
Old Apr 8, 2002 | 02:36 PM
CivicEK.PDX's Avatar
Default Re: headgasket? (erniecars)
I used the middle layer.....and have had no problems (about 1k miles later). Just make sure you install it right....otherwise youll have a mess. Good luck
Old Apr 8, 2002 | 03:13 PM
voltronR34's Avatar
it will change your timing. I can't imaging anything else will be affected. But I suppose that layer is there for a reason.
Old Apr 8, 2002 | 03:24 PM
FSTASNTZ's Avatar
Reliability, no problems. I ran the Spoon 2 layer for over a year, then I built a new engine. Never had a problem with it.
I have heard of removing the middle layer, but I have not tried this myself. Figured I would leave it up to someone else to do, and rivet it so it would not come apart on instalation....
Jason
Old Apr 9, 2002 | 10:07 PM
riceboy's Avatar
Default Re: headgasket? (FSTASNTZ)
the closest to stock as you can get will always be your most reliable option, the question you ask yourself is "if my wallet isnt big enough to do it right, then is my wallet big enough to fix it when it blows up?"
Old Apr 9, 2002 | 11:39 PM
ExospeedAMcrx's Avatar
Default Re: headgasket? (riceboy)
if you do go 1 layer.. make sure you copper spray the whole thing to help it seal better.
Wil
Old Apr 10, 2002 | 12:29 AM
C4wrx's Avatar
Default Re: headgasket? (exospeedAMcrx)
i had a friend who did this in his b16 and blew the head gasket after about a month, do it right the first time, dont do it the cheap way
HPfreak
Sep 23, 2011 04:53 PM
NoAhIDontThinkSo
Jan 25, 2011 05:43 PM
Brycen
Jan 1, 2010 02:20 AM
Joeski99Si
Apr 22, 2009 09:57 PM
Speed Infliction
May 2, 2006 12:35 PM
