It Wont shift, unless manually shift
Old Apr 24, 2006 | 11:01 AM
Metal Head's Avatar
Default It Wont shift, unless manually shift
got an Accord, Automatic, I have a CEL, but dont know how to read it.
Anyway, My problem is when I put it into drive, it wont go, although, If i Manually shift it, itll go ( put it into L then 2 etc...)
Can anyone help?
Like I said, it has Check engine light, so it could be the automatic trans lock sylenoid, but I dont know how to check the codes. is it the same as Civics? OBD1? put a jumper wire in the port and check the number the light blinks?
Old Apr 24, 2006 | 01:14 PM
philadd's Avatar
Default Re: It Wont shift, unless manually shift (slayerknot)
Year and engine would be helpful.
Autozone will check your codes for free.
Old Apr 24, 2006 | 01:35 PM
Metal Head's Avatar
Default Re: It Wont shift, unless manually shift (philadd)
shouldnt matter, a standard automatic trans, wont shift, why?
I belive its a 91 Accord, mabey you know the engine size?
Old Apr 24, 2006 | 03:19 PM
xx_unstable_xx's Avatar
i had this same problem. i have an '03 accord cp. ex and after i'd had it for about 2 months the transmission would delay on its shifts and the rpm's would get up into the 5000-6000 range without me accelerating hard at all and then finally shift. it would only do this on occasion before it finally wouldn't shift at all and i had to get a new transmission. luckily it was under warranty and we didn't ahve to pay for it.
-i hope this helps-
Old Apr 24, 2006 | 03:44 PM
BLKFLSH's Avatar
Default Re: It Wont shift, unless manually shift (xx_unstable_xx)
If it's a 91, obd1, use the blue plug and count the blinks. Long blinks for 10 space, and short blinks one's space. Example: 3 long blinks, and 2 short blinks would be code 32. It may have more than one code, so go through it a few times. Good luck
Old Apr 24, 2006 | 04:57 PM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slayerknot &raquo;</TD></TR><TR><TD CLASS="quote">shouldnt matter, a standard automatic trans, wont shift, why?
I belive its a 91 Accord, mabey you know the engine size? </TD></TR></TABLE>
Because there are different methods to finding the code, depending on what year Accord it is. Engine matters because certain years w/ the V6 have extended warranties. So, yes, it does matter.
More importantly, you need to get the code before anything else. The code may tell you the exact problem, or it may just let you know something else is wrong.
Old Apr 24, 2006 | 05:27 PM
gianinline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slayerknot &raquo;</TD></TR><TR><TD CLASS="quote">shouldnt matter, a standard automatic trans</TD></TR></TABLE>
.. of course it matters. Different trannies can have different "common" problems and specific ways to be fixed.
Old Apr 24, 2006 | 06:10 PM
YeuEmMaiMai's Avatar
All accord tranmission starting from about 90 on up are electronically controlled. IF the computer does not tell it to shift, it won't.
Your selector lever could be the cause of the problem -multiple ranges selected- computer sees the car in Drive and Park at the same time and therefore will not let car move.......
Old Apr 25, 2006 | 03:28 PM
Metal Head's Avatar
Default Re: It Wont shift, unless manually shift (YeuEmMaiMai)
ok, thank you all for the help, this is actually for my friend, he is out of town and this started happening to him, and I am not familiar with accords. I am going to have to make a visit to go see if I can fix his problem.
ragestuff
Jun 14, 2011 07:13 PM
honda_tuner20
Feb 11, 2010 10:54 PM
00Accord03Odyssey
Jan 22, 2009 06:30 PM
wlfpck
Nov 5, 2004 09:04 PM
alb_accord
May 13, 2004 06:22 AM
