06 Salavaged Accord
Im interested in buying an 06 salvaged accord. what would be a ballpark figure to get the frame straightend and what problems could i expect from a front end collision as far as issues with the engine, drivetrain, etc.
that's the thing about salvage vehicle there's no two alike.
A/C line is toasted, front impact beam needs to be replace, radiator, hoses, frame straighen
one frontal damaged salvage might just need to replace the front beam and straighten which is spare change
another frontal damage salvage might need to replace motor mount(or worst, the motor), transmission mount(or worst transmission), axles, abs line, etc
the last one will cost 10 times more
if you don't know what you are looking for, don't even bother.
they all look the same but there's alot more than that
Don’t buy it; if you have way too much money go play casino, that way you only worry about one night, if you buy that Salvaged Accord then you’ll worry every night
Do you own a body shop? If so, and you have access to honda parts, you might be able to rebuild the car to original condition and have many years of reliable service. Downside is that you will NOT be able to sell the car for anything near what a not salvage car in the same condition would be worth
My 94 was salvaged at 60K and here I am at 145K and everything still works on the car including the A/C. I have had to replace only the following items since I have had it
1. Thermostat
2. Lower ball joint driver side
3. Rad cap
4. Driver side outer CV joint.
5. recharge A/C twice (once when I got it and once last year)
Car is getting to the point where it is going to turn into a rust bucket (rear quarters and hood) but I can get another 2 years out of it, it's all good.....
1. Thermostat
3. Rad cap
smarsquid
Sep 24, 2004 10:59 PM
