Engine cranks won't start
Old Apr 24, 2006 | 06:35 AM
2step's Avatar
Default Engine cranks won't start
I have a 95 accord it died at a stop light and won't start. ecu light stays on with jumper wire, no codes, fuses, grounds, wiring, and components in dizzy check ok. Turns over can smell fuel no spark with plug ground out on block. This is stock no mods done, It has me stumped change ecu, icm, had coil tested, Do I need to change the dizzy or is that just a quick fix for the non-mechanically inclined. I'm and old carb guy and new at all this fancy stuff under the hoods with all this computer run stuff. thanks for any help in educating an old fart.
Old Apr 24, 2006 | 08:05 PM
Top Ramen's Avatar
Default Re: Engine cranks won't start (2step)
ignitor?
Good luck.
Old Apr 24, 2006 | 10:03 PM
cutt's Avatar
main relay
Old Apr 25, 2006 | 09:32 AM
IMALLSLO's Avatar
Reach underneath the dash and bang on the main relay while trying to start it. Its a brown box looking thing with 6 pin connector tucked under on the kick panel. It should start but rec. getting a new one.
jiggsaw
Jul 4, 2012 03:42 AM
slamed91
May 19, 2012 06:16 AM
RobEK
Sep 28, 2009 06:30 PM
.ShawnD.
Aug 31, 2002 02:57 PM
No More Civic
10
Aug 27, 2002 09:35 AM
