"Rotating machine" for better welds?
Old Apr 24, 2006 | 12:30 AM
hondaapi's Avatar
Default "Rotating machine" for better welds?
I´m not sure if this is the right english word, but do you have pics of "rotating machines"? - Such machine where you put something on and it rotates on its own so that you just need to weld?
I saw such a machine here in Germany in a welding company but it was a gigant machine. I´m searching for a small one?
Thanks
Old Apr 24, 2006 | 02:29 AM
Motorhead_AZ's Avatar
Default Re: "Rotating machine" for better welds? (hondaapi)
Something like this?
If so, the manual versions are called a rotary table. The ones with an electric motor are called turn tables. You can buy them in various sizes on ebay.
Old Apr 24, 2006 | 04:02 AM
RSWEPN's Avatar
I have seen a differential shop use a rotating machine when it welds the end plates on its diff housing's. It was just a home made machine and did the job fine.
Old Apr 24, 2006 | 04:24 AM
hondaapi's Avatar
Default Re: (RSWEPN)
yes it was a machine like this. thanks.
has anybody ever worked with one of this? experiences?
Old Apr 24, 2006 | 10:58 AM
pngfolife's Avatar
Default Re: (hondaapi)
Get an orbital welder.
Old Apr 24, 2006 | 11:59 AM
kylemarhx's Avatar
i've used one before for production MIG welding, and it was great. but i don't see how it would be nearly as useful in one-off TIGing.
Old Apr 24, 2006 | 03:31 PM
cua0's Avatar
pipe rollers and rotary tables are great for production mig stick, a lot more difficult with tig, better off to just do it in position or stop & rotate, get really good at your tie-in's and nobody will ever notice it wasn't rolled.
Old Apr 24, 2006 | 06:09 PM
.RTErnie's Avatar
Default Re: (cua0)
if you could control the speed of the table with yet ANOTHER pedal...you might be onto something.
Old Apr 25, 2006 | 04:35 AM
Default Re: (~RTErnie~)
Or the rotation could just be adjustable through a ****, sort of like the turn table people use to work with clay.
Old Apr 25, 2006 | 07:00 PM
damnraz's Avatar
Default Re: (Motorhead_AZ)
They call this a rotab , I work in the aerospace industry and they do use a pedal to control the rotation of the assembly you are making and also variable speed adjustments. Argon is also fed into this rotating table and makes your work look a lot cleaner
I-VTECRX
Dec 18, 2010 08:28 PM
wade
Welding / Fabrication
23
Jan 27, 2008 09:32 AM
Fred Allen Burge
Sep 25, 2006 05:21 PM
RACEPAK
14
Aug 21, 2006 07:01 PM
JMFabrications
Feb 2, 2005 04:07 PM
