is this too low?
i have a 94 del sol S w/ H&R race springs on koni yellow shocks..
problem is that i think i'm a little too low. everytime i go over a bump, my inner fender area shreds a piece of my front tire.
i think the rear clunking noise i (and everybody else who hears clunks in the rear) experiencing also. can i solve this by rolling my front and rear fenders/quarter panel?
i'm planning to buy 17x7 wheels also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schrader »</TD></TR><TR><TD CLASS="quote">is it hitting the plastic liner, or your fender?</TD></TR></TABLE>
it's hitting the metal piece inside my fender. i took out all my fender linings
Is it tucked? If so, it's too low.
I guarantee you're riding the bumpstops too.
I would raise the car and/or get stiffer front springs if you want to be that low.
My old tires were stredded on the inside with h&r sports the same way that you're describing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 »</TD></TR><TR><TD CLASS="quote">wheel size, offset, and tire size and model/brand?
and is this the front or rear?</TD></TR></TABLE>
205/50/15
205/50/15
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the soL that could »</TD></TR><TR><TD CLASS="quote">
205/50/15</TD></TR></TABLE>
Wheel size, like 15x7 or 15x6.5 etc. Wheel offset. Tire manufacturer.
Wheel size, like 15x7 or 15x6.5 etc. Wheel offset. Tire manufacturer.</TD></TR></TABLE>
i don't think it matters... but i have oem acura gsr wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the soL that could »</TD></TR><TR><TD CLASS="quote">i don't think it matters... but i have oem acura gsr wheels.</TD></TR></TABLE>
15"x6" +45mm offset
It does matter. If you're having rubbing problems with these wheels, then it will be very hard to find a 17"x7" wheel that will have a high enough offset to clear your fender. Most 17s I've seen have a +40mm offset.
Yes, it's too low for 17s. Probably not for GSR wheels w/ 195/50/15 tires though.
15"x6" +45mm offset
it's everything in there... that piece next to the pinch seam... i'm thinkin about running h&r sports because of this issue. i hate the clunking when i hit little bumps on the road. handles like a dream, but drives worse than a tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">what perch are you running them on with the Konis? Maybe try running the same spring on the top perch for a little higher ride height, but with stiff springs? </TD></TR></TABLE>
stock...the rear is in the middle. as for the fronts, i am runnin it on the top. there's only 2 perches on the fronts. which suks... lol
Costco
Jan 7, 2008 05:11 PM
GraphiteMW
Apr 17, 2007 09:19 AM
the soL that could
Apr 23, 2006 11:26 PM
