WTF!?@!?!@ DID I DO WRONG?????
Old Apr 23, 2006 | 05:57 PM
TylerB's Avatar
Default WTF!?@!?!@ DID I DO WRONG?????
Ok, long story short. Car is finally driveable, started the motor, went for the 1st test drive...
I depress the clutch and move a whole damn 2ft and I snap my axle.
now tell me
<U>WTF did i do wrong</U>
Old Apr 23, 2006 | 06:06 PM
importfan0103's Avatar
depressed how fast and how high of a rev?
Old Apr 23, 2006 | 06:20 PM
TylerB's Avatar
Default Re: (importfan0103)
I slipped the clutch, just like I normally would. Rpm's were anywhere from 1k-1.5k. I was pulling out of the garage.
I'll get pic's on monday morning.
Old Apr 23, 2006 | 06:41 PM
DOHCtorTHRUST's Avatar
Default Re: (EGG#)
wrong axles?
Old Apr 23, 2006 | 06:43 PM
aquabob89's Avatar
* B A N N E D *
Default Re: (DOHCtorTHRUST)
whats the set up?
Old Apr 23, 2006 | 06:47 PM
Soccerking3000's Avatar
Default Re: (aquabob89)
its all that torque our motors have you gotta be careful
Old Apr 23, 2006 | 07:26 PM
TylerB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aquabob89 &raquo;</TD></TR><TR><TD CLASS="quote">whats the set up?</TD></TR></TABLE>
Rebuilt stock d16y7 in an EG hatch. I'm assuming my the reason it broke was because it was too short???
When we put the axle in the boots were a bit tighter then normal but nothing too bad. The axle was clipped in and the spindle nut was tight and torqued
Old Apr 23, 2006 | 08:30 PM
japan4racing's Avatar
sounds to me like they were separated before you put them in. how did you remove them?if the joint is separated the boot will be tighter and as soon as you put some force on them it will let go completely. let us know how you removed them
Old Apr 23, 2006 | 10:37 PM
TylerB's Avatar
Default Re: (japan4racing)
I didn't take them out of the car, a friend gave me two sets of axles...
Old Apr 23, 2006 | 10:57 PM
Schrader's Avatar
Default Re: (EGG#)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGG# &raquo;</TD></TR><TR><TD CLASS="quote">I didn't take them out of the car, a friend gave me two sets of axles...</TD></TR></TABLE>
Kick his *** for giving you those
Old Apr 24, 2006 | 11:14 AM
TylerB's Avatar
Default Re: WTF!?@!?!@ DID I DO WRONG????? (EGG#)
Here's the damage:
Old Apr 24, 2006 | 11:18 AM
fmrprojects's Avatar
that sucks. your homie gave you some faulty parts. but next time just check and see if all the joints are still intact before installing., looks like the clip for the boot came loose and everything just came out
Old Apr 24, 2006 | 11:26 AM
TylerB's Avatar
Default Re: WTF!?@!?!@ DID I DO WRONG????? (fmrprojects)
How do you check to make sure that ***** in place and it wont do this again/???
Old Apr 24, 2006 | 03:31 PM
just go to an auto parts store they have a lifetime waranty real cheap so u dont hvae to worry
Old Apr 24, 2006 | 05:24 PM
TylerB's Avatar
$60 autozone w/ lifetime warranty
btw, I think I found the problem
The driver side caliper was stuck open. The hub/wheel was locked.
Could this be the problem?
Old Apr 24, 2006 | 05:26 PM
kaoss_11's Avatar
B A N N E D
that axle was already on its last leg
Old Apr 24, 2006 | 05:34 PM
FalkenSiR's Avatar
your friend just owned you
Old Apr 24, 2006 | 06:27 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">your friend just owned you </TD></TR></TABLE>
Old Apr 24, 2006 | 06:30 PM
Mr. Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japan4racing &raquo;</TD></TR><TR><TD CLASS="quote">sounds to me like they were separated before you put them in. how did you remove them?if the joint is separated the boot will be tighter and as soon as you put some force on them it will let go completely. let us know how you removed them</TD></TR></TABLE>
my friends old y7 ate axles and trannys for lunch. lol good luck with the fix
Pagley
Jun 29, 2008 03:56 PM
wu tang
Dec 14, 2007 05:31 AM
greddy13
Jul 4, 2006 05:24 PM
MrPotatoeHead
Oct 23, 2005 07:17 PM
Ivan
28
Jul 1, 2003 07:49 PM
