need help replacing inner tie rod...
Old Apr 23, 2006 | 03:08 PM
See Are X's Avatar
Default need help replacing inner tie rod...
...Ive searched and couldnt find any good info. I need to replace my passenger inner tie rod. I dont really know what to do or what to buy. Could someone give me some pointers? and list what parts I need to get? I'm thinking its just #1 and #20...thanks...
Old Apr 23, 2006 | 10:44 PM
sleepingEg8's Avatar
Default Re: need help replacing inner tie rod... (See Are X)
#1 is the tie rod and #20 is the lock washer... you usually need to get a new one because it gets bent apon install.. While you are doing the inner tie rod, you would probably want to get a new boot too.. alignment is mandatory after changing any of these parts.. Good luck!
Old Apr 24, 2006 | 02:04 PM
See Are X's Avatar
Default Re: need help replacing inner tie rod... (sleepingEg8)
thanks...
...also, could some write up some quick instructions on how to take the inner tie rod off?
Old Apr 24, 2006 | 07:13 PM
See Are X's Avatar
ttt
Old Apr 25, 2006 | 10:44 AM
See Are X's Avatar
Default Re: (See Are X)
blah
Old Apr 26, 2006 | 09:51 AM
See Are X's Avatar
anyonnnnnnnnne?
Old Apr 26, 2006 | 10:38 AM
AMG's Avatar
AMG
Havent replaced one yet, but you should invest in a haynes/helms manual for your car. You can also google "How to Tie Rod" and you should get results. Good Luck.
whitehope77
Honda CR-V & Element
Mar 28, 2016 09:46 PM
Freshdot
Apr 18, 2015 06:37 PM
rasinhell
May 3, 2005 09:23 PM
cliff666
Feb 21, 2004 04:55 AM
