Which power steering pump for my LS?!
I just put an LS in my 95 coupe and everythings working fine. The only problem I ran into was my power steering pump. I was originally told that I could reuse my stock power steering pump but when I went to put it on I noticed the place where the bolts match up to the bracket are not the same. The braket is in a straight line but the pump has offset mounting locations not to mention even if I spaced it out with something the pulley still sticks out too far. The other day I grabbed a pump off a 94 teggy from the junk yard thinking it was the right one for sure but it uses a V-belt and doesnt have the same hose fitting as the original one does. Does anyone know what pump/bracket/lines I need to use to make this work? Thanks in advance!
