from a dx to a mini-me, do I still need the injector resistor box?
Old Apr 23, 2006 | 10:50 AM
crxcess's Avatar
Default from a dx to a mini-me, do I still need the injector resistor box?
I know I would need it when going from dpfi to mpfi, but what if I swap out the d15 for a d16z6 engine and computer? does obd1 still use a resistor box?
Old Apr 23, 2006 | 11:06 AM
SVOboy's Avatar
obd1 injectors do not use the resistor box.
Old Apr 23, 2006 | 01:38 PM
sauceja's Avatar
Default Re: (SVOboy)
So would you just wire the injectors straight to computer and forget the whole mpfi swap?
Since the harness only has 2 injectors you still only need two wires but can you put them into a plug so it is easier to take engine out instead of having to cut anything?
Just curious.
Old Apr 23, 2006 | 01:41 PM
SVOboy's Avatar
You need the mpfi swap still.
When I did it I just got an obd1 IM/TB and used that, wired up my injectors like I should, then ran the four injector power wires together to a common power source to bypass where the injector resistor box would be.
Old Apr 23, 2006 | 09:14 PM
sauceja's Avatar
Can you post a picture of that or send it to me. sauceja@yahoo.com
Old Apr 23, 2006 | 09:18 PM
SVOboy's Avatar
I would but I taped the hell out of all my wiring. You basically take the two power wires (yel/blk) off the old injectors, wire together, then wire all four of the power wires from the new injectors to them.
Old Apr 24, 2006 | 01:58 AM
pinecone's Avatar
But what if you left the injector box and tried to run the car, would it still work?
Old Apr 24, 2006 | 03:07 PM
sauceja's Avatar
Default Re: (pinecone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone &raquo;</TD></TR><TR><TD CLASS="quote">But what if you left the injector box and tried to run the car, would it still work?</TD></TR></TABLE>
And by wiring all the power wires together or do you mean ground ones?
The power wires should still be at ports A1, A3, A5 & A7 right?
Then the computer will send ground to the correct ones anyways because A3 & A7 or A1 & A3 would be factory spliced together. So by running new power wires they should all be covered.
Correct me if I am wrong on this.
Old Apr 24, 2006 | 04:47 PM
SVOboy's Avatar
The power is constant and you wire switched grounds to the ecu. You can't run obd1 injectors with a resistor box without ******* things up.
Old Apr 26, 2006 | 07:44 AM
sauceja's Avatar
Cool Thanks man from here on out I will continue my journey with the big shiny red thing up in the upper right hand corner but I appreciate the advice.
And sorry for the thread jack it wasn't intentional.
Old May 26, 2006 | 09:56 AM
mntuner2's Avatar
To clarify:
OBD0 Computer - OBD1 Injectors
OBD0 Computer - OBD0 Injectors - OBD0 Res. Box
efjones9
Jul 11, 2010 06:13 PM
SupraRXZ
Jan 31, 2006 09:07 PM
ZCcivicBOI
Sep 9, 2005 10:57 AM
jadugartir
Feb 23, 2005 03:05 PM
fearless_dsm
Mar 10, 2004 04:24 PM
