Power window problems
Old Apr 23, 2006 | 09:19 AM
Prof007's Avatar
Default Power window problems
ok i have 2000 Civic Ex 2dr.
Short version: What can i do to better the drivers side window operation?
Long version:
the window on the drivers side has been acting screwy since i got it.
the window is very slow coming down and up at the mid-way point.
sometimes the front part has so much friction it will pull the backside out of weather seal while coming up.
Also some how the window got scratched up a few times coming up (i hear the sounds) the scratches where on the outside.
So i took the panel off. couldn't see anything that could put scratches on the window. I put grease on all the moving parts. put some kinda high temp grease in the Tracks. the window seemed to be in better shape but after a few days the problem is alot worse....
Old Apr 23, 2006 | 09:40 AM
Relic1's Avatar
silicone spray on the window track helped mine out a lot.
as far as the scraping, pull the panel and plug back in the switch, run it up and down a few times, it should be obvious what's causing it.
Old Apr 23, 2006 | 10:07 AM
Prof007's Avatar
Default Re: (Relic1)
thanks. just regular silicone spray right?
yeah i thought it would be obvious too but i couldn't find anything even close to the windows (nothing withing 2 inches). my theory it was scraping one of the metal bars but it hasn't done that since i looked at it. oh well.
damdash
Jun 24, 2009 05:08 PM
samson1
Jun 21, 2004 08:35 AM
cosmicjim
Jan 25, 2003 08:36 AM
clean
Nov 1, 2001 08:16 PM
