LS 5th Gear...what parts do I need?
Im putting an LS 5th gear in a Civic Si tranny. What parts do I need to do this? I ask in the Type R forum, because I know alot of you guys put LS or GSR 5th in when you do a new FD. I need the main gear, the counter gear...what else? Syncros? My local Acura dealer knows absolutely nothing. They're a bunch of dummies that sell a product and thats it.
Thanks!!
Thanks!!
Not a final drive change, just 5th gear. Only need 2 pieces to change a gear, and those are the gear itself.
LSD, well that's a different story . . .
.....what are you, a sissy?
j/k
you just need the gears for 5th and that's it.
Change final drive, flywheel, clutch, and lsd while you're in there.....
j/k
I wouldn't go putting an LS 5th in your tranny. I recently did this with my ITR motor/G2 GSR YS1 cable tranny and I hate it. I'm swapping it out for a 01 GSR 5th. It will be a good comprimise. Here's a plot that may help you out....
http://www.imagestation.com/picture/...c.jpg.orig.jpg
If the link doesn't work, copy and paste it.
You will also need a 32mm hex nut for your countershaft, a drain and fill plug washer for your tranny, and 3 quarts of Honda MTF
. Best of luck.
. Best of luck.Thread
DelsolioGSR1996
Transmission & Drivetrain
27
Jan 24, 2013 02:13 PM
fizic
10
Feb 23, 2004 08:03 AM
