rpm is off...
OK..so i jus did my headers, replaced the o2 sensor....had problems ...had code 1 and 15...solved that.......but NOW my rpm is actin wierd...like...it doesnt rev past..5 or 5.5.....seems like it make 5 the redline point...sumtimes it only gets to 4!?!...so yea...any help?
Well richy, I've been told ECU's go into safe mode when they throw codes to prevent high reving which could do damage to your engine if theres still a problem.
Reset your ecu by disconnecting the battery, try that.
PS I dont know if that info's 100% true, but it's worth a try.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi »</TD></TR><TR><TD CLASS="quote">thanks......tried it....yea its fyne now...</TD></TR></TABLE>
My work here is done...
