xtd cltch intall got a problem i think HELPPP
Old Apr 22, 2006 | 08:46 PM
DB1_559's Avatar
Default xtd cltch intall got a problem i think HELPPP
ok so i just complete my clutch swap for a xtd stage 3 on my z6 .here my problem when im in 1st/rev it shake and then smooth out can this be cause by my pressure cause i got real tired and put enough pressure so i can get rolling or is it because of the stage
Old Apr 22, 2006 | 08:48 PM
bluemax189's Avatar
Default Re: xtd cltch intall got a problem i think HELPPP (jdmboi86)
yeah, when i did teh stage 3 on mine, it sucked at first, takes some getting used to.
Old Apr 22, 2006 | 10:18 PM
DB1_559's Avatar
it jumps not shake
Old Apr 23, 2006 | 02:15 AM
Schrader's Avatar
So basicly its slipping pretty violently?
Old Apr 23, 2006 | 07:03 AM
Jmunk's Avatar
Clutch chatter, did you break this in by dropping the clutch a few times at decent rpm, these need to be broken in this way.
Old Apr 23, 2006 | 07:38 AM
Soccerking3000's Avatar
Default Re: (Jmunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmunk &raquo;</TD></TR><TR><TD CLASS="quote">Clutch chatter, did you break this in by dropping the clutch a few times at decent rpm, these need to be broken in this way. </TD></TR></TABLE>
what??? i have never heard anyone doing this, you are supposed to take it easy for 500 miles not go out and launch it...
Old Apr 23, 2006 | 08:49 AM
Hondaciv95VX's Avatar
Default Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">what??? i have never heard anyone doing this, you are supposed to take it easy for 500 miles not go out and launch it...</TD></TR></TABLE>
my thoughts also...you can glaze that **** over.
Old Apr 23, 2006 | 09:41 PM
DB1_559's Avatar
im taking it easy utill my 500 miles so any one know the cause
Old Apr 24, 2006 | 03:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">im taking it easy utill my 500 miles so any one know the cause</TD></TR></TABLE>
its a 6-puck, there is your cause.
Old Apr 24, 2006 | 04:00 AM
egredspools's Avatar
Default Re: xtd cltch intall got a problem i think HELPPP (Soccerking3000)
is it 6-puck-<U>sprung </U> or unsprung cause on the street unsprung is really shitty
Old Apr 24, 2006 | 07:11 AM
nocturnaldragon's Avatar
Thats one option or you can do the "Quick" methode and drop it a few times and break it in quick,
Old Apr 24, 2006 | 07:14 AM
Default Re: (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Thats one option or you can do the "Quick" methode and drop it a few times and break it in quick,</TD></TR></TABLE>
does that have any negative effects?
Old Apr 24, 2006 | 08:56 AM
schardbody's Avatar
yes, glazing the friction material on the clutch, scoring the flywheel, warping the flywheel. not a good idea to dump a brand new clutch, especially a 6puck. clutch chatter is normal until it breaks in, sure dumping it will make it quit chattering quicker, but not the brightest idea.
Old Apr 24, 2006 | 10:12 AM
DB1_559's Avatar
ITS SPRUNG SO ITS NORMAL AND MY STOCK FLYWHEEL IS SCORE A LITTLE WILL THAT AFFECT ANY THING CAUSE I DIDNT HAVE REAL TIME TO PUT ON MY JUN FLYWHEEL AND PLUS WAITING TO BUY THE BOLTS TOO BUT ILL DO A NEW CLUTCH WHEN A SCORE A LSD S20 THANKS FOR THE INFO ANYMORE
Old Apr 24, 2006 | 10:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">ITS SPRUNG SO ITS NORMAL AND MY STOCK FLYWHEEL IS SCORE A LITTLE WILL THAT AFFECT ANY THING CAUSE I DIDNT HAVE REAL TIME TO PUT ON MY JUN FLYWHEEL AND PLUS WAITING TO BUY THE BOLTS TOO BUT ILL DO A NEW CLUTCH WHEN A SCORE A LSD S20 THANKS FOR THE INFO ANYMORE</TD></TR></TABLE>
stop yelling learn to use periods and speak coherently then we can help you a little more...
Old Apr 24, 2006 | 10:17 AM
schardbody's Avatar
yeah i cant put a sentence together w/ that cluster of words you just spent 30mins typing.
Old Apr 24, 2006 | 02:37 PM
DB1_559's Avatar
sorry bout that writeing im at work and we alway got to spell every letter in cap lock my bad
WalkerGSR1
Oct 22, 2006 11:48 AM
RemerLex11
Jul 23, 2005 04:53 PM
RidinStock
Oct 31, 2004 02:58 PM
2k1 SSM GSR
Jul 9, 2004 01:46 PM
