intake gasket
Old Apr 22, 2006 | 08:02 PM
zccr-xsi's Avatar
Default intake gasket
anyone know where there a write up on changing intake gasket for a dohc zc??or i guess even for 89 integra motor would work.
Old Apr 22, 2006 | 08:29 PM
YasRex's Avatar
Default Re: intake gasket (vteckillenzc)
double posting won't help.
Old Apr 23, 2006 | 12:28 AM
STREETWERKZ's Avatar
Default Re: intake gasket (YasRex)
take manifold off, take old gasket off, put new gasket on, put the manifold back on.
Old Apr 23, 2006 | 04:18 AM
Sikocivic's Avatar
Default Re: intake gasket (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">take manifold off, take old gasket off, put new gasket on, put the manifold back on. </TD></TR></TABLE>
Sounds simple enough
Old Apr 23, 2006 | 04:59 AM
crxnj's Avatar
Theres a bracket/support back there you gotta remove....Then remove manifold,,,,remember to disconnect the engine wire harness from the manifold as well as some of the vacuum lines that may be holding it in..Then remove the manifold..Then remove the gasket ,,and theres probably going to be alot of gasket sealer all over the head so put some paper towels or newspaper or whatever in the intake ports of the head..Then I like to use gasket remover and a scraper,,have to be real carefull not scratch **** up..Apply new gasket sealer and then the gasket..I like to use rtv gasket sealer personally..Then install the manifold back onto the engine along with bolting back up the bracket/support..All bolts get torqued down to 17ft/lbs...And on the intake manifold make sure to tighten them in a criss-cross pattern,,start from the inside out and I like to do it in steps....Then hook back up the engine harness and vacuum hose(s) that you took off..
Edit--Do zc engines even have a intake manifold support/bracket back there?
Modified by Mr.speaker at 9:55 AM 4/23/2006
Old Apr 23, 2006 | 05:46 AM
Autoworks's Avatar
Default Re: intake gasket (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Edit--Do zc engines even have a intake manifold support/bracket back there?</TD></TR></TABLE>
Yes, 2 nuts conntect it to to mani, 2 to the block, and 2 more bolts on its side. They are all 12mm and cake to get off if your laying under the car with a ratchet and 10" extension
Old Apr 23, 2006 | 05:48 PM
zccr-xsi's Avatar
i got good look at the mani and it look like its going to be tight getting it out?ill get it no prob?thanbks for the info.
im going to clean the mmani really good before i put it back on.anyone know if they make one of them isolator gaskets for the dohc zc?? i looked all over and cant find one.i seen them for sohc zc.but not the dual cam motor.
Old Apr 23, 2006 | 05:50 PM
Tippyman's Avatar
U may wanna pull the whole head if u have no other choice
Old Apr 24, 2006 | 03:52 AM
zccr-xsi's Avatar
not bad ideal since the h/g never been chaNGED.BUT I HAVNT NEVER PULLED THE HEAD OFF THIS MOTor yet?i rather just change the intake gasket.
Old Apr 24, 2006 | 04:14 AM
Autoworks's Avatar
Default Re: (vteckillenzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">not bad ideal since the h/g never been chaNGED.BUT I HAVNT NEVER PULLED THE HEAD OFF THIS MOTor yet?i rather just change the intake gasket.</TD></TR></TABLE>
The HG isn't something that you just have to routinely change.
Old Apr 24, 2006 | 04:26 PM
zccr-xsi's Avatar
Default Re: (Autoworks)
yea i know but i want to change the h/g before i boost!
aryiman98civic
Feb 24, 2007 07:02 PM
boosted ek
Jun 27, 2005 07:01 PM
253EK
Jun 10, 2004 10:16 PM
MR. MIYAGI
Mar 26, 2004 08:01 PM
dualknuttz1
Jan 23, 2004 08:37 PM
