SMAW
Old Apr 22, 2006 | 03:33 PM
C_H_A_D's Avatar
Default SMAW
there is a school by me that teaches shielded metal arc welding (SMAW)
What exactly is that? Also what is Oxy-Fuel?
Thanks I stick weld/arc. I want to go to school and get certified.
Old Apr 22, 2006 | 04:32 PM
jdm monkey's Avatar
Default Re: SMAW (NINJASWORD)
smaw = stick welding
Old Apr 22, 2006 | 08:42 PM
vha27's Avatar
Default Re: SMAW (jdm monkey)
oxy fuel is another method of joining metal together, more appropriately its oxygen (oxy) and acetylene (fuel), both gases which come from 2 different cylinders, each gas goes thru a regulator (each one is set at different pressures based on the application) then thru hoses and into a torch, the two gases are mixed in the torch tip and then burned to produce a flame, this flame is hot enough to to melt the work to be joined, forming a molten puddle, from this the ,etals to be joined can either be fuse welded together or filler can be deposited, steel, stainless steel as well as aluminum can ge gas welded, stainless and aluminum will most likely require some type of flux paste
there are 3 different types of flames that can be set with the torch, each flame having a different temperature for the type of work to be done, carburizing (excess acetylene), neutral (equal oxygen and acetylene), and oxidizing (excess oxygen)
a shielding gas is not needed in this process because the outer flame acts as a blanket because it actually consumes the surrouding oxygen around the puddle preventing the puddle from being contaminated
and last i recommend learning this process, im currently in school to get certified and the first thing we were taught was how to gas weld, you learn what welding is all about, puddle control and manipulation, its helps a whole lot once you move onto TIG welding
Old Apr 23, 2006 | 05:58 AM
C_H_A_D's Avatar
Default Re: SMAW (vha27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vha27 &raquo;</TD></TR><TR><TD CLASS="quote">
and last i recommend learning this process, im currently in school to get certified and the first thing we were taught was how to gas weld, you learn what welding is all about, puddle control and manipulation, its helps a whole lot once you move onto TIG welding</TD></TR></TABLE>
Wow, That was really detailed to you. I think I will learn that it sounds neat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm monkey &raquo;</TD></TR><TR><TD CLASS="quote">smaw = stick welding</TD></TR></TABLE>
Thank you
v8killaz
Welding / Fabrication
Sep 8, 2014 10:02 PM
turbo_rsx
Apr 28, 2012 12:11 PM
thegatekeeper14
Mar 28, 2010 05:06 PM
ivsihi
Feb 14, 2005 07:52 AM
turbologist
Oct 7, 2003 06:00 PM
