Suspension & Brakes Theory, alignment, spring rates....
Bump stops on KYB & H&R ????
Old Apr 22, 2006 | 03:19 PM
LvN's Avatar
LvN
Default Bump stops on KYB & H&R ????
Do I use bump stops on a KYB AGX w/ H&R sports?? Mine didn't come with any so I wonder if I need it? Basically all I did was put the springs into the struts and then got the stock top hats on top and applied the nuts on the hats. I didn't compress the springs. Did I miss anything?
Old Apr 22, 2006 | 03:44 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Bump stops on KYB & H&R ???? (blkcivicpn0i)
You should have re-used your bumpstops from your old suspension. For Sports I don't think they need to be cut. You should also push down on the tophat HARD and screw the nut down as much as possible. Make sure you use two nuts for obvious reasons.
Old Apr 22, 2006 | 03:52 PM
LvN's Avatar
LvN
Default Re: Bump stops on KYB & H&R ???? (JDM_Ej)
yea.. I pressed on it hard and screwed it on. Thanks for the info!
Sl0wEK
Aug 21, 2008 11:39 PM
flipinxgeez
Suspension & Brakes
17
Nov 1, 2007 08:24 AM
SwiftTypeR
Apr 9, 2007 10:38 PM
Civicse
11
Dec 13, 2005 07:49 PM
