Changing brakes from diagonal split to front\rear split(will this work?)
96 integra, using a 40\40 prop valve
Red lines are front brake lines
Blue lines are rear brake lines
Green are lines from MC
Pardon the crude paint job-
normal setup-
Proposed setup-
Question is will the new setup work?
normal setup-
Proposed setup-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory Matthews »</TD></TR><TR><TD CLASS="quote">im jus wondering why?</TD></TR></TABLE>
To make something else I am doing easier.
if you search in the RR/auto X forum you will find a few topics covering this.
i don't under stand what this has to do with suspension thoguh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">if you search in the RR/auto X forum you will find a few topics covering this.
i don't under stand what this has to do with suspension thoguh.</TD></TR></TABLE>
I did find a few posts, but nothing that would give me a concrete answer.
We dont have a brake specific forum, nor is it really car specific either. I just knew that alot of the brake guys hung out in here.
I have been told it should work.
if you read the topics then you know that some people say YES and others say NO.
there are people who have done it and it worked.
Did you think of PMing them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 »</TD></TR><TR><TD CLASS="quote">youre going to tee-in the rears so you can put in a brake bias adjuster to the rear circuit?</TD></TR></TABLE>
thats my guess
thats my guess
Its so I can run a line loc off a single line from the MC.
Yes I have PMed a few people and pointed them to this thread, currently waiting for responses. Its not like I am doing this tomorrow or even next month.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon »</TD></TR><TR><TD CLASS="quote">Question is will the new setup work?</TD></TR></TABLE>
Not the way you want it. You can't use the stock prop-valve.
If you were going through all the trouble of that, I dont see it being much more work (except more money) to plumb in a dual master cylinder setup with a balance bar. Willwood and baer and ap racing make setups for this, though you will have to calculate your system volume and pressure etc...
Either way would still be as 'anti-failsafe' as the other compared to the stock diagonal split system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 »</TD></TR><TR><TD CLASS="quote">If you were going through all the trouble of that, I dont see it being much more work (except more money) to plumb in a dual master cylinder setup with a balance bar. Willwood and baer and ap racing make setups for this, though you will have to calculate your system volume and pressure etc...
Either way would still be as 'anti-failsafe' as the other compared to the stock diagonal split system.</TD></TR></TABLE>
Too much, I only wanted to do it this way if I could use the stock valve.
Beau Gotti
Oct 17, 2008 08:49 AM
DIYaccord
82
Apr 4, 2004 08:04 PM
