B18b radiator hoses.
I was told to use 93ls hoses to make the swap complete. Was this info right? Also can I use my stock radiator, the in and out ports are different sizes than the engine ports, so the hose I use would have to taper (which I havent ever seen). Thanks in advance.
-Jake
-Jake
I used my stock lower rad. hose. I wish I had grease when I put it on, it took a couple hours to squeeze it over the LS side. It works. I will change it though to 93.
