bunch of parts
itr inner and outter valve springs and itr retainers-$200 p/s
b16 oil squirters-$40p/s
gsr knock sensor-$40p/s
b16 crank, in perfect cond-$100p/s
gsr obd1 injectors-$100 p/s
clutchmasters stage 3 disc and pressure plate-$330 shipped cod
chipped 90 ls ecu 5spd-$150 p/s
98 civic ex vtec 5spd ecu-$150 p/s
98 civic ex wire harness-$150 p/s
crx hf harness,4injector harness-$150 p/s
stock 90 ls 5spd ecu-$75p/s
b16 obd0 injectors-$100 p/s
t3 turbo, needs rebuilding,chipped compressor wheels-$100 p/s
drag kit gen 1 hks bov with flange-$100 p/s
vortech fmu with bracket-$100
autometer boost gauge-$20p/s
zc dohc oil pan tapped for turbo, professionally welded-$100 p/s
cartech fmu-$100 p/s
steel braided line for turbo oil line-$50
ls shortblock-$250 so cal only
crx si trans and axles-$250
crx zc trans-$200
b16/zc halfshaft-$75p/s
front crx crossmember,in perfect cond,with those two bars which connect to lower suspension-$200 p/s
jdm crx side markers and corners-$100 p/s
jdm vin badge plate-$50 p/s
b16 sir cams-$100 p/s
jdm zc cams-$100 p/s
b16 valve cover-$40 p/s
ls valve cover-$40 p/s
stock sprockets-$20 p/s
stock 90 integra guage cluster-$40p/s
90 integra jdm climate control-$100 p/s
90 integra wingswest mugen copy wing-$150
94 integra wingswest mugen copy wing-$150
you can email me or call me at 9097213949, i cant ship the shortblock or trans
[Modified by boostinq, 1:23 PM 4/8/2002]
[Modified by boostinq, 1:26 PM 4/8/2002]
crx zc trans-$200
russian_racer
10
Apr 8, 2003 09:54 AM
wickedEFguy
Jun 6, 2002 02:36 PM
