Removing 94 accord caliper!
Ok I have to remove my rear caliper on my 94 accord and it seems almost impossible...Ive unhooked one of the brake lines...everything else seems impossible there are a few bolts but they are impossible to get to...has anyone done this before or know what to do?..or does anyone have a diagram of a caliper?
should be ez as pie dude. top and bottom pins need removing ... be careful if they r rusted removing them if you want to reuse any of the protective rubber and sheet.
http://www.hondaautomotivepart...IN%29
if i misunderstood what you r trying to do sorry.
What ?
Just remove that caliper bolts "C" look at the clear pictures that I post, yes they may tight, 1 try clockwise then counter-clockwise, put some wd40 or somthing
you'll have your brake pads and caliper on your lap.
anyone got any ideas on how I can remove it? or...you can tell me this..what do i need to do if my piston came out..do i just screw it back in or what?..nothing seemed to break...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowered94accord »</TD></TR><TR><TD CLASS="quote">that doesnt tell me how to remove the caliper that just tells me how to replace brake pads...thanks though</TD></TR></TABLE>
look at #13, the caliper is mismounted in the picture if you need to rebuilt the bastard, get a locking clamp and chock the brakeline, and take off the screw that bolted down the brake line to the caliper.
you need to rebuild/replace the seal if the piston fell off
portugueboy10
Sep 3, 2012 05:00 PM
89_LXi
Jun 25, 2001 07:50 PM
