i think i got screwed.. ehh i hate trannys
Old Apr 22, 2006 | 11:16 AM
haveaniceday's Avatar
Default i think i got screwed.. ehh i hate trannys
well i bought a transmission off ebay "post" to have only 60k miles on it ... lets fast forward to after install (A2M) ..
-when the cars off i can get it, into every gear except 3rd
-when the car is running every gear except 3rd, and 4th grinds so bad i didnt wanna force it in
-i checked the tranny fluid from the fill hole its dripping out so thats good ..
-i bled the lines pretty good but the pedal isnt very stiff(act hdss) like i thought it would be
- during start up theres a grinding noise ...
.. so im leaning more towards 3rd and 4th gear are gone ..
slight possiblity the clutch is in backwards?
what do you guys think?
Old Apr 22, 2006 | 07:43 PM
Default Re: i think i got screwed.. ehh i hate trannys (haveaniceday)
up for some answers
Old Apr 23, 2006 | 12:22 AM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaniceday &raquo;</TD></TR><TR><TD CLASS="quote">- during start up theres a grinding noise ... </TD></TR></TABLE>
Sounds like some sort of installation error. When you start the car, the clutch is depressed, so therefore nothing inside the transmission is moving. If there is grinding during startup, it sounds like the starter isn't properly aligned with the flywheel. That could be due to improper fitment of the input shaft into the clutch disk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">slight possiblity the clutch is in backwards? </TD></TR></TABLE>
As far as I know, that's not possible.
Old Apr 23, 2006 | 07:56 AM
Default Re: i think i got screwed.. ehh i hate trannys (EnzoSpeed)
as i searched i found one guy put the clutch on backwards.. and he said his clutch pedal still stayed soft after he bled and bled it .. thats kinda my situation .. only one thing to do take the tranny off and see if did anything wrong ..
Old Apr 23, 2006 | 08:01 AM
non-VTEC's Avatar
i don't think its possible to put the clutch disc on backwards since you will pretty much distroy it trying to. and it would be pretty hard to bolt the pressure plate down if it was on backwards....
sounds like you got a bad tranny...........take it apart or send it back to the *** you bought it from.
Old Apr 23, 2006 | 01:53 PM
92HB_HB's Avatar
Default Re: i think i got screwed.. ehh i hate trannys (non-VTEC)
Can't be the seller. EGAY is very reliable and trustworthy...
on a serious note.. its the tranny,, it was junk 2 begin w/... i'd never buy anything from eGay, unless I can see the item 1st..
Old Apr 23, 2006 | 04:27 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">
Old Apr 23, 2006 | 04:29 PM
EnzoSpeed's Avatar
Default Re: i think i got screwed.. ehh i hate trannys (92HB_HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote">Can't be the seller. EGAY is very reliable and trustworthy...
on a serious note.. its the tranny,, it was junk 2 begin w/... i'd never buy anything from eGay, unless I can see the item 1st..</TD></TR></TABLE>
I used to make a living buying/selling car parts on ebay. 99% of the parts that are currently on my car came off of ebay.
Old Apr 24, 2006 | 04:39 AM
i know you take a chance buying anything used .. but you know the fucked up part .. after i bought the tranny i even emailed the seller and asked if anything was wrong with the tranny .. any grinds, leaks.. anything .. he said just fill it up with fluid.. it was post to be from a 99 and as i was installing it i saw a 97 stamped on the housing and thought did i get screwed? and i just continued anyway .. and well now im pulling it out and its getting sent to gear speed .. i just dont wanna take a chance on anything used .. getting it rebuilt seems smarter, its more money but i know gear speed will do it right, so im not worried
Old Apr 24, 2006 | 11:19 AM
EnzoSpeed's Avatar
How much is the rebuild going to cost?
Old Apr 25, 2006 | 03:59 AM
i havent talked to gear speed personally but i think anywhere from $1000 - 1500 .. unless someone presents me with a Y8 tranny in mint condition and i can believe them i will get a used one .. ive possibly thought about buying a d15b lsd tranny from HMO .. *shrugs shoulders*
Old Apr 25, 2006 | 04:28 AM
Cuda70's Avatar
Are you absolutely sure your cluth is bled and adjusted correctly?
Old Apr 25, 2006 | 08:13 AM
Honda Bull's Avatar
Default Re: i think i got screwed.. ehh i hate trannys (Cuda70)
Grinding could be the starter. But your transmission is bad. Definately need another. I personally wouldn't even look at that one except for possible spare parts if you happen to blow another tranny. Even then, using parts that have been exposed to all that is probably going on inside that tranny wouldn't be the best idea.
Good luck, man.
lcsej1
17
Mar 8, 2009 08:27 AM
slayersluck
Jan 13, 2007 11:36 PM
RTW DC2R
Sep 5, 2003 07:36 AM
Young_R
Dec 13, 2002 06:30 PM
erikgsr
Oct 16, 2002 10:40 PM
