Suspension & Brakes Theory, alignment, spring rates....
New wheel studs replacement without removing hub?
Old Apr 22, 2006 | 06:00 AM
Sifu's Avatar
Default New wheel studs replacement without removing hub?
Ok guys I know this has been covered before but I cant seem to find a good thread with PICTURES on how to do it properly.
ANyways thing is I stripped a wheel stud and am in the process of replacing it, I managed to remove the old stud by cutting it off but am having trouble installing a new one in.
From what I read it is possible to install new ones in without removing the hub by grinding it but I cant seem to find any good picture to show HOW MUCH I need to grind off.
I've grinded one side flat on the "head" of the bolt but still cant seem to manage to stick it in, btw the new stud I got from honda is 34mm long.
I've also read threads of people saying that there is a "notch" or space on the hub where I can spin the stud to and hammer it out but I cant seem to find this at all!! Can someone please elaborate??!!
THanks!
Old Apr 22, 2006 | 08:22 AM
chinese buffet's Avatar
Default Re: New wheel studs replacement without removing hub? (Sifu)
A few years ago I broke a stud while taking my front wheels off on my EJ1. I tried for hours to find a place or opening to "hammer" the broken one out. I couldn't find one so finally I took it to a friend's shop and he used the special hub puller tool to pull the hub off. Its a bitch, I hope it doesn't happen again anytime soon.
Hope that helps,
CB
Old Apr 22, 2006 | 01:25 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: New wheel studs replacement without removing hub? (chinese buffet)
Took me 3 seconds to find this one (search, "stud" in archived 92-00 civic/del sol forum [second one down]). Let me know if that helps...
https://honda-tech.com/zerothread?id=907985
Old Apr 22, 2006 | 03:05 PM
Sifu's Avatar
Default Re: New wheel studs replacement without removing hub? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Took me 3 seconds to find this one (search, "stud" in archived 92-00 civic/del sol forum [second one down]). Let me know if that helps...
https://honda-tech.com/zerothread?id=907985</TD></TR></TABLE>
Dude if you're telling me to search before for I post then I think you should re-read the post, thats WITH removing the hub
dre2day
Feb 16, 2008 07:56 AM
yh23
Suspension & Brakes
Jun 2, 2005 10:10 PM
dj_seloe
Oct 15, 2004 07:45 AM
bleebdat
Feb 19, 2003 11:03 AM
TurBoXBirD16
Jul 9, 2002 07:48 PM
