Koyo Radiator install NEED HELP!
Old Apr 21, 2006 | 06:46 PM
Young L's Avatar
Default Koyo Radiator install NEED HELP!
Been trying to install this new koyo radiator in my 94 Accord with a SOHC . Having lots of clearence issues with the fan shroud hits the front motor mount the drain plug not clearing the front cross member. IM GOING CRAZY!
Old Apr 21, 2006 | 08:32 PM
gianinline's Avatar
Default Re: Koyo Radiator install NEED HELP! (Young L)
Are you sure you are getting the radiator in the right position?! There are two rubberer ends under the radiator, that were meant to sit properly to absorb some shock and keep it in place. If they don't fit properly, the radiator will be standing higher than it is supposed to.
Old Apr 22, 2006 | 03:53 AM
Young L's Avatar
i got the two rubber pieces
Old Apr 22, 2006 | 06:06 AM
NAiL05's Avatar
You get the Koyo aluminum replacement? You sure if they gave your the right one for your application?
Old Apr 22, 2006 | 06:39 AM
Young L's Avatar
Yes it is the right radiator. Ive checked the koyo website and its the right part number.
Old Apr 22, 2006 | 07:38 AM
mycargov6room's Avatar
are you bolting the fan shroud on the radiator before installing it?
You should remove the fans, install the radiator by it self first, then bolt the fan shroud on after.
Old Apr 22, 2006 | 07:45 AM
Young L's Avatar
Default Re: (mycargov6room)
^^^^ tried that. Basically what it is you need a slim fan to clear the motor mount on the passenger side of the engine bay. AAHHHRRRRRRR! Im ticked, koyo's website doesnt say anything about needing a slim fan. Ive checked all over cant find info anywhere. Im going to have to put my stock leaking radiator back in
Old Apr 22, 2006 | 08:27 PM
NAiL05's Avatar
Default Re: (Young L)
Look for FAL fans. They make slim fans for our applications.
Old Apr 22, 2006 | 09:01 PM
YeuEmMaiMai's Avatar
compare the new one to the old one. I have a 94 LX and there is a large gap between my rad and the rest of the engine even with the fan attached.
Old Apr 22, 2006 | 09:18 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Young L &raquo;</TD></TR><TR><TD CLASS="quote">Basically what it is you need a slim fan to clear the motor mount on the passenger side of the engine bay. AAHHHRRRRRRR! Im ticked, koyo's website doesnt say anything about needing a slim fan. Ive checked all over cant find info anywhere. Im going to have to put my stock leaking radiator back in </TD></TR></TABLE>
Yes, the Koyo radiators are thick.
Here are two links with some info.:
https://honda-tech.com/zerothread?id=716039
https://honda-tech.com/zerothread?id=178090
Old Apr 22, 2006 | 09:49 PM
NAiL05's Avatar
Default Re: (YeuEmMaiMai)
You might have ordered the racing version of the Koyo? I know the race version is a bit thicker.
Old Apr 22, 2006 | 10:57 PM
Young L's Avatar
Default Re: (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=178090</TD></TR></TABLE>
Old Apr 23, 2006 | 05:42 PM
bjaccord's Avatar
I had to notch my front crosmember to clear the drain plug. Not sure on fans, I'm running 3 slims. L8r
lsvtecEM1
Mar 19, 2012 05:18 AM
lsvtecEM1
Mar 18, 2012 10:38 AM
210southstar
Aug 25, 2010 05:28 AM
ahead
Nov 25, 2002 02:04 PM
4doorH22
Jan 19, 2002 12:12 PM
