A'PEX V-AFCII Smoke???
A'PEX V-AFCII Smoke would this work for me..?
I have a 95 accord ex Automatic that i'm getting ready to turbo.. SO Because i can't tune an automatic ecu would this controller work for me. I'm using the drag turbo kit.. so I'm only going to be boosting about 10psi at the max.. this is for a automatic.. or is there something better.. please help asap..
Do you mean the black V-AFC II?
If so, you can run the AFC hack with your setup, but I don't recommend it.
You'd be better off with something along the lines of GReddy E-Manage, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda1313 »</TD></TR><TR><TD CLASS="quote">which one would be better to use..??
AND this works For an Automatic Accord</TD></TR></TABLE>
didn't he just answer your question?
10psi on slushbox, then plan to buy something that would work for both type of trans because you WILL be swapping tranny, rather you will be swaping auto tranny or standard after the one you have is gone.
not to be rude but
"10psi, keep the tranny good bye"
emanage is have more option to play with but again, it's all up to the tuner
not to be rude but
I guess he did.
The only reason I asked is becaue i've posted questions before and people don't read all you have put. So they give you a wrong answer.
So I was just double checking..
Thank you I will be looking into both
2000Accord5sp
Jan 23, 2004 05:37 PM
