Spark Plug heat?
Old Apr 21, 2006 | 02:34 PM
pimpaccord801's Avatar
Default Spark Plug heat?
Alright... I don't know jack about spark plugs!! Thought this would be a good place to start! I searched a little bit, but didn't find much!
Anywho--I'm looking for new spark plugs and the website I found some on has them from heat 6 up to 9.
What's the difference? Obviously one produces more heat than the others, but what's the difference in performance?
I'm looking to mod the hell outta my engine too, it's basically stock at the moment (with the exception of cold air intake and exhaust)... is it worth getting the higher heat spark plugs on a stock engine?
Old Apr 21, 2006 | 03:14 PM
iam7head's Avatar
Default Re: Spark Plug heat? (pimpaccord801)
The temperture is referred as HEAT RANGE.
it's like motor oil, get the grade you need for your car, you don't get anything from using the wrong type of oil or in this case different heat range of plugs.
for stock motor, just use the heat range honda recommend.
colder plugs found their way into turbo/supercharged motor and alot of n2o equipped motor
Old Apr 21, 2006 | 03:46 PM
philadd's Avatar
Just use the recommended NGK plugs. ZFR5F-11 (stock #2262)
Rob.
May 6, 2009 01:31 PM
project dc2
Jan 21, 2006 10:33 AM
gamakichi77
Feb 18, 2004 02:02 AM
JDlvl InTEGRA
Jan 30, 2003 12:42 PM
JDM R98
Jul 31, 2001 07:23 PM
