water temp gauge install
Old Apr 21, 2006 | 02:24 PM
Green Lude 93's Avatar
Default water temp gauge install
i was wondering if it is possible to use the existing water temp sensor on the head with an aftermarket gauge and still have accuracy? Reason i ask is because my gauge didnt come with the sensor and it is suppose to. So i cant check the resistance between the stock and aftermarket sensor. anyone have an idea. i dont have a thermometer to check either. any insight would help. thanx
Old Apr 21, 2006 | 07:53 PM
.God.'s Avatar
Default Re: water temp gauge install (Green Lude 93)
only if the aftermarket gauge is set to use the EXACT same range that the OEM sender puts out, which is not the case. You need the proper sending unit that gauge is looking for.
s13hero
Aug 22, 2011 07:34 AM
steveharrmr23
Nov 11, 2008 07:31 AM
streetcartuner
Jan 12, 2008 09:59 AM
seanb18c1
Feb 17, 2002 08:26 AM
